0misclose Posted May 14, 2024 Posted May 14, 2024 I've been given a design file for a terrace which consists of thousands of individual lines and polylines which I would like to merge into continuous 3D polylines (They need to remain 3D). They appear end to end, I've tried all the tips I could find (including mapclean in civil3D) and nothing is working for me. The only thing that I've noticed is that the elevations seem a bit funky in the properties dialog when you click on some of the lines (ID inspect and 3D view looks fine). I was wondering if anyone could have a look and potentially help me out with what I'm doing wrong. Any help would be appreciated, cheers. Terrace Example.dwg Quote
0misclose Posted May 15, 2024 Author Posted May 15, 2024 4 minutes ago, BIGAL said: I just typed "Join" and appeared to work. Hi Bigal, So you're telling me when you select all the lines and run the join command you end up with 12 polylines? The best I get is the bottom alignment being partially complete. Most of the lines don't join at all. Quote
BIGAL Posted May 15, 2024 Posted May 15, 2024 I used Bricscad and just did Join and selected all line work. There is a fuzz setting mine may be different will try to find it. "PEDIT command>Multiple>select entities>Join>Fuzz Factor.... HELP explains the PEDIT command structure, you can review it for tips and ideas." 1 Quote
Steven P Posted May 16, 2024 Posted May 16, 2024 Same here, 'Join', select all, and they all join. What version of CAD are you running and are there any error messages? I am on 2022, all good. Quote
SLW210 Posted May 16, 2024 Posted May 16, 2024 How are you selecting the 3D Plines? They all join here. I first did the JOIN>ALL>Enter, then I used a left-to-right window to select them all, then I used a right-to-left window to select them all, I ended up with 12 3D Plines all methods. Terrace Example SLW210.dwg Quote
0misclose Posted May 17, 2024 Author Posted May 17, 2024 I appreciate the help guys. I'm running Autocad 2022 and Civil 3D and had the same issue on both. I had a random breakthrough where it randomly worked yesterday (I didn't do anything different, just selected everything and ran JOIN). I've tried to do it again now and it doesn't work. PEDIT doesn't give me the option to join when I select them all either. Not sure what the root cause of the issue is. Cheers. Quote
SLW210 Posted May 17, 2024 Posted May 17, 2024 Do you have all updates to AutoCAD? Can you do a "Reset to Defaults"? How to reset AutoCAD to defaults (autodesk.com) Though you might need to run a repair or reinstall. How to repair or reinstall an AutoCAD installation (autodesk.com) Quote
