double line duct work with eccentric reducer
I have been having some good luck with being under the gun trying to get work out with dead lines and have two many project due it not funny. We have 5 projects due and not enough time to get them done. The existing stuff has been done thanks for “Lee Mac’s” help.
That’s Lee, couldn’t had done it without you bubby. Now the “new” work we need to show double line duct work and there need to have Eccentric Reducer.
Flat on one side and reducer on the other side. But it would be nice to select witch side the flat side in on. We got 3 days to complete just one project?
Now I need a double line ductwork that has Eccentric Reducer?
Is there any lisp routines out there.
Sorry Lee,
I had not had time to try the Double line ductwork with Eccentric Reducer. It was crazy around here trying to make are dead line and not having time to try the lisp routine out. I have a little time to day to try it out. This looks like a pipe lisp routine? Thanks again
No problem, whenever you get a minute :)
I created the program a while back and just thought it might suit your needs :)
Cheers
Lee
