pyou Posted May 7 Share Posted May 7 (edited) Is it possible to convert a single 3dpolyline zigzag string into two separate 3dpolylines using a lisp code? Images attached Thank you for help! Testt.dwg Edited May 8 by pyou dwg example added Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 8 Share Posted May 8 (edited) This should get you close to what you need. with minimal error handeling only allows you to select 2 polylines at a time & they have to have the same number of vertex for this to work. ZZPoly.mp4 ZZpoly.lsp Edited May 8 by mhupp Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 8 Share Posted May 8 I think i did that backwards. 1 Quote Link to comment Share on other sites More sharing options...
devitg Posted May 8 Share Posted May 8 17 hours ago, pyou said: Is it possible to convert a single 3dpolyline zigzag string into two separate 3dpolylines using a lisp code? Images attached Thank you for help! @pyou It seem OP ask to convert ONE ZIGZAG 3dpoly on two 3dpoly . Is it so? Please upload a before and after DWG Quote Link to comment Share on other sites More sharing options...
pyou Posted May 8 Author Share Posted May 8 5 hours ago, devitg said: @pyou It seem OP ask to convert ONE ZIGZAG 3dpoly on two 3dpoly . Is it so? Please upload a before and after DWG see Images, original 3d polyline before is a zigzag and after are two separate 3d polylines. What you don't understand? Quote Link to comment Share on other sites More sharing options...
pyou Posted May 8 Author Share Posted May 8 (edited) 16 hours ago, mhupp said: I think i did that backwards. yes mhupp it is supposed to be opposite. Zigzag is original 3d polyline and two new 3d polylines needed. I have attached example of zigzag 3d polyline Edited May 8 by pyou Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 9 Share Posted May 9 5 hours ago, pyou said: yes mhupp it is supposed to be opposite. Zigzag is original 3d polyline and two new 3d polylines needed. I have attached example of zigzag 3d polyline Top down is usually how things flow. I guess you got an undo lisp now. 2Poly.mp4 2Poly.lsp 1 Quote Link to comment Share on other sites More sharing options...
