HI ALL
WANT LISP FOR INPUT DATA IN CAD
i have a ground level
sample
x y z
17 20 2.5
21 24 3.4
25 28 4.3
29 32 5.2
33 36 2.5
37 40 3.4
of plot i have x,y & z corrdinate i havve to plot this in autocad
but plotting z valu shown on display point and text is one block
after that when i ckeck list of that it is on same x,y&z cordinate.
please refer sample attached:)
thanks
harshad:)
SAMPLE.pdf
Try this one
;; local defun
;; entmake block
(defun makepoint  ()
 (if (not (tblsearch "BLOCK" "POINT_ELEV"))
     (initget 6)
     (setq hgt (getreal "\n  Enter text height of attribute <2.5>: "))
     (if (not hgt)
(setq hgt 2.5))
     (entmake
(mapcar	'cons
	(list 0 8 2 70 10 3)
	(list "BLOCK" "0" "POINT_ELEV" 2 '(0 0 0) "POINT_ELEV")))
     (entmake
(mapcar	'cons
	(list 0 8 62 10 210 50)
	(list "POINT" "0" 0 (list 0 0 0) '(0 0 1) 0.0)))
     (entmake
(mapcar	'cons
	(list 0 8 62 10 40 70 1 210 3 2)
	(list "ATTDEF"
	      "0"
	      0
	      (list (/ hgt 2) (* hgt 2.5) 0)
	      2.5
	      9
	      "x"
	      '(0 0 1)
	      "Topo point X coordinate"
	      "XCOORD")))
     (entmake
(mapcar	'cons
	(list "ATTDEF"
	      "0"
	      0
	      (list (/ hgt 2) (* hgt 1.5) 0)
	      2.5
	      9
	      "y"
	      '(0 0 1)
	      "Topo point Y coordinate"
	      "YCOORD")))
     (entmake
(mapcar	'cons
	(list "ATTDEF"
	      "0"
	      6
	      (list (/ hgt 2) (/ hgt 2) 0)
	      2.5
	      8
	      "z"
	      '(0 0 1)
	      "Topo point Z coordinate"
	      "ZCOORD")))
     (entmake
(mapcar	'cons
	(list 0
	(list "ENDBLK" "0"))))))
;; main programm
(defun C:PP  (/ att_tag ent new_value next next_data osm point_list)
 (makepoint)
     (alert "Something wrong\nprogramm stopped")
     (exit)
     (princ)))
 (setq osm (getvar "osmode"))
 (setvar "cmdecho" 0)
 (setvar "osmode" 0)
 (setq	point_list
 (list
   '(17 20 2.5)	'(21 24 3.4) '(25 28 4.3) '(29 32 5.2) '(33 36 2.5) '(37 40 3.4)))
 (foreach point  point_list
   (command "._-insert" "POINT_ELEV" point 1 1 0)
   (setq ent (entlast))
   (setq next ent)
   (while (setq next (entnext next))
     (setq next_data (entget next))
     (setq att_tag (cdr (assoc 2 next_data)))
     (cond
((eq (strcase "XCOORD") att_tag)
 (setq new_value (rtos (car point) 2 1)))
((eq (strcase "YCOORD") att_tag)
 (setq new_value (rtos (cadr point) 2 1)))
((eq (strcase "ZCOORD") att_tag)
 (setq new_value (rtos (caddr point) 2 1))))
     (entmod
(subst (cons 1 new_value) (assoc 1 next_data) next_data))
     (entupd ent)
 (command "._zoom" "_e");by suit
 (setvar "osmode" osm)
 (setvar "cmdecho" 1)
;; TesT : (C:PP)
(prompt "\n====================================\n")
(prompt "\n\t>>>\tType PP to execute ... \t>>>\n")
(prin1)
~'J'~
thanks fatty but i have lots of ground levels
witch i send u is a sample i have more than 10,000
x,y,z cordinate let"s try u r best
thanks
harshad
Guest Alan Cullen
Do you have a file of the XYZ coords, and is the file "space" delimited?
i hope u know about the ground improvements
from site i got x,y,z data i want to import it into the cad
but z valu i want in display thats all our douctment is
Confidential if any idia about to makeing script or lisp of that x,y,z points
and done this input in one time
thanks for reply
harshad
Guest Alan Cullen
you got me, I've never used excell files before. But there are many threads here about it. Do a search and find the answer.
See This Sample
Cordinate .exel File
Thanks
Harshad
Keep watching this thread
~'J'~
See how it will work for you
;; PP.lsp
;; read Excel, draw points in Acad as blocks with attributes
;; local defun
;; entmake block
(defun makepoint  ()
     (initget 6)
     (if (not hgt)
(setq hgt 2.5))
     (entmake
(mapcar	'cons
     (entmake
(mapcar	'cons
     (entmake
(mapcar	'cons
	(list "ATTDEF"
	      "0"
	      0
	      2.5
	      9
	      "x"
	      '(0 0 1)
	      "XCOORD")))
     (entmake
(mapcar	'cons
	(list "ATTDEF"
	      "0"
	      0
	      2.5
	      9
	      "y"
	      '(0 0 1)
	      "YCOORD")))
     (entmake
(mapcar	'cons
	(list "ATTDEF"
	      "0"
	      6
	      2.5
	      8
	      "z"
	      '(0 0 1)
	      "ZCOORD")))
     (entmake
(mapcar	'cons
	(list 0
;; local defun
;; to read the Excel range
(defun EXR  (FilePath ShtNum StrRange /	ExcelApp ExcData Sht UsdRange Wbk)
;; based on function "EXD" from this page:
;; http://www.cadforyou.spb.ru/index.php?current_section=section_functions_page
 (vl-load-com)
 (setq ExcelApp (vlax-get-or-create-object "Excel.Application"))
 (vla-put-visible ExcelApp :vlax-true)		  ; or :vlax-false if you want
 (vlax-put-property ExcelApp 'DisplayAlerts :vlax-false)
 (setq	Wbk (vl-catch-all-apply
      'vla-open
      (list (vlax-get-property ExcelApp "WorkBooks") FilePath)
 (setq	Sht (vl-catch-all-apply
      'vlax-get-property
      (list (vlax-get-property Wbk "Sheets")
	    "Item"
	    ShtNum
 (vlax-invoke-method Sht "Activate")
 (setq	UsdRange (vlax-get-property
	   (vlax-get-property Sht 'Cells)
	   "Range"
	   StrRange)
ExcData	 (vlax-safearray->list
	   (vlax-variant-value
	     (vlax-get-property UsdRange 'Value2)
 (setq
   ExcData (mapcar
      (function (lambda (x) (mapcar 'vlax-variant-value x)))
      ExcData
 (vl-catch-all-apply
   'vlax-invoke-method
   (list Wbk "Close")
 (vl-catch-all-apply
   'vlax-invoke-method
   (list ExcelApp "Quit")
 (mapcar
   (function
     (lambda (x)
(vl-catch-all-apply
  (function (lambda ()
		(if (not (vlax-object-released-p x))
		    (vlax-release-object x)
		    (setq x nil)
   (list UsdRange Sht Wbk ExcelApp)
 (gc)
 (gc)
 ExcData
;;      main part       ;;
(defun C:PP  (/	Att_Tag	Ent Filepath Headflag New_Value	Next Next_Data
      Osm Poinlist Response Shtnum Strrange)
 (or (vl-load-com))
 (setq	FilePath (getfiled "Select Excel file to read :"
		   (getvar "dwgprefix")
		   "xls"
		   16
 (initget 6)
 (setq ShtNum (getint "\nEnter the sheet number <1> : "))
 (if (not ShtNum)
   (setq ShtNum 1))
 (setq	strRange (strcase
	   (getstring "\n  Enter address of used range <A1:C99>: ")))
 (if (eq "" strRange)
   (setq strRange "A1:C99"))
 (initget "Yes No")
 (setq	Response (getkword
	   "\n   Is the Excel table has the headers? (Y/N) <Y>: "))
 (if (not Response)
   (setq Response "Yes"))
 (if (eq "Yes" Response)
   (setq HeadFlag T)
   (setq HeadFlag nil))
 (setq PoinList (EXR FilePath ShtNum strRange))
 (if HeadFlag
   (setq PoinList (cdr PoinList)))
 (if PoinList
     (makepoint)
  (exit)
  (princ)))
     (setvar "osmode" 0)
     (foreach point  PoinList
(setq next ent)
  (cond
  (entmod
  (entupd ent)
   (alert "Trouble with reading Excel data")
;; TesT : (C:PP)
(prin1)
~'J'~
ok fatty try u r best
best of luck!
thanks
harshad
;; PP.lsp
;; local defun
;; entmake block
(defun makepoint  ()
     (initget 6)
     (if (not hgt)
   (setq hgt 2.5))
     (entmake
   (mapcar    'cons
     (entmake
   (mapcar    'cons
     (entmake
   (mapcar    'cons
       (list "ATTDEF"
             "0"
             0
             2.5
             9
             "x"
             '(0 0 1)
             "XCOORD")))
     (entmake
   (mapcar    'cons
       (list "ATTDEF"
             "0"
             0
             2.5
             9
             "y"
             '(0 0 1)
             "YCOORD")))
     (entmake
   (mapcar    'cons
       (list "ATTDEF"
             "0"
             6
             2.5
             8
             "z"
             '(0 0 1)
             "ZCOORD")))
     (entmake
   (mapcar    'cons
       (list 0
;; local defun
 (vl-load-com)
         'vla-open
         'vlax-get-property
           "Item"
           ShtNum
          "Range"
          StrRange)
          (vlax-variant-value
 (setq
   ExcData (mapcar
         ExcData
 (vl-catch-all-apply
   'vlax-invoke-method
   (list Wbk "Close")
 (vl-catch-all-apply
   'vlax-invoke-method
 (mapcar
   (function
     (lambda (x)
   (vl-catch-all-apply
               (setq x nil)
 (gc)
 (gc)
 ExcData
;;      main part       ;;
 (or (vl-load-com))
              "xls"
              16
 (initget 6)
 (if (not ShtNum)
   (setq ShtNum 1))
 (initget "Yes No")
 (if (not Response)
   (setq HeadFlag T)
 (if HeadFlag
 (if PoinList
     (makepoint)
     (exit)
     (princ)))
     (setvar "osmode" 0)
   (setq next ent)
     (cond
     (entmod
     (entupd ent)
;; TesT : (C:PP)
(prin1)
~'J'~
fatty u r done very good job but 1 probleam z valu takes one diget after point for that its take maxzimum 3 diget after point
Take a look at RTOS function in the Help file
~'J'~
Guest Alan Cullen
Cheers, Fatty,
Just trying to boost my post count here:
rtos ......... Converts a number into a string
(rtos number [mode [precision]]) mode = 2 (decimal) precision = ?
Alan, sorry for the late
(rtos number [mode [precision]]) mode = 2 (decimal) precision = number of digits
say to display 3 digits it should :
(rtos SomeNumericVariable 2 3)
Thanks
~'J'~
thank u very much fatty u solve my problem once again
thanks
harshad:) :) :)
  • 1 year later...
thank...very useful to my part..
cheers
oliver
;; PP.lsp
;; local defun
;; entmake block
(defun makepoint ()
(initget 6)
(setq hgt (getreal "\n Enter text height of attribute : "))
(if (not hgt)
(setq hgt 2.5))
(entmake
(mapcar 'cons
(entmake
(mapcar 'cons
(entmake
(mapcar 'cons
(list "ATTDEF"
"0"
0
2.5
9
"x"
'(0 0 1)
"XCOORD")))
(entmake
(mapcar 'cons
(list "ATTDEF"
"0"
0
2.5
9
"y"
'(0 0 1)
"YCOORD")))
(entmake
(mapcar 'cons
(list "ATTDEF"
"0"
6
2.5
8
"z"
'(0 0 1)
"ZCOORD")))
(entmake
(mapcar 'cons
(list 0 8)
;; local defun
(vl-load-com)
'vla-open
'vlax-get-property
"Item"
ShtNum
"Range"
StrRange)
(vlax-variant-value
(setq
ExcData (mapcar
ExcData
(vl-catch-all-apply
'vlax-invoke-method
(list Wbk "Close")
(vl-catch-all-apply
'vlax-invoke-method
(mapcar
(function
(lambda (x)
(vl-catch-all-apply
(setq x nil)
(gc)
(gc)
ExcData
;; main part ;;
(or (vl-load-com))
"xls"
16
(initget 6)
(setq ShtNum (getint "\nEnter the sheet number : "))
(if (not ShtNum)
(setq ShtNum 1))
(getstring "\n Enter address of used range : ")))
(initget "Yes No")
"\n Is the Excel table has the headers? (Y/N) : "))
(if (not Response)
(setq HeadFlag T)
(if HeadFlag
(if PoinList
(makepoint)
(exit)
(princ)))
(setvar "osmode" 0)
(setq next ent)
(cond
(entmod
(entupd ent)
;; TesT : (C:PP)
(prin1)
any update instead of Z or elev..change into point labels or point numbering.
no its not...seems as what he did of "fixo" for harshad export from excel.
will i just found out another routine...try to found out what is this..but they are looking another files..
  ;; Internal error handler defined locally
 (defun al_err (s)                   ; If an error (such as CTRL-C) occurs
                                     ; while this command is active...
   (if (/= s "Function cancelled")
     (princ (strcat "\nError: " s))
   (if al_oe                         ; If an old error routine exists
     (setq *error* al_oe)            ; then, reset it
   (setq aliasi (close aliasi))
   (setvar "cmdecho" al_oce)         ; Reset command echoing on error
 ;; Body of alias function
 (if *error*                         ; Set our new error handler
   (setq al_oe *error* *error* al_err)
   (setq *error* al_err)
(DEFUN C:TOPO ()
(COMMAND "LAYER" "N" "SIGN" "C" "1" "SIGN" "")
(COMMAND "LAYER" "N" "LEVEL" "C" "7" "LEVEL" "")
(COMMAND "LAYER" "N" "PNT_CEN" "C" "7" "PNT_CEN" "")
(COMMAND "LAYER" "N" "PNT_NUM" "C" "2" "PNT_NUM" "")
(initget (+ 1 2 4))
(setq raz (getreal "Imenitelj razmere .........: "))
(initget (+ 1 2 4))
(setq fnt (getreal "Visina ispisa [mm] .........: "))
(setq oang (getreal "Zakosenje ispisa [dec. step.] ...: "))
(setq fnt (* fnt (/ raz 1000)))
;(setq dia (* fnt 1.25))
(setq dia (* fnt 0.)
;(setq dia fnt) ############## TP
;(setq dis (/ fnt 5))
(setq dis (/ fnt 4))
(setq dpn (/ fnt 4))
(setq imefnt "1")
(setq ffile "ROMANS")
(setq wfac 0.75)
(setq non "N")
(COMMAND "PDMODE" "32")
(COMMAND "PDSIZE" "0.125")
(COMMAND "STYLE")
(COMMAND imefnt)
(COMMAND ffile)
(COMMAND fnt)
(COMMAND wfac)
(COMMAND oang)
(COMMAND non)
(COMMAND non)
(COMMAND non)
 (setvar "CMDECHO" 0)
 (setq f (getfiled "Fajla tacaka" "" "*" 4))
 (setq fr (open f "r"))
 (setq k 0 Cr " " Row " ")
 (while (/= Row nil)
   (setq Row (read-line fr))
   (if (/= Row nil)
       (SPC)
       (if (> k 1)
         (TRIMS)
       (VALU)
       (setq Pn (substr Row 1 (- k 1)))
       (TRIMS)
       (SPC)
       (TRIMS)
       (VALU)
       (setq y (atof (substr Row 1 (- k 1))))
       (TRIMS)
       (SPC)
       (TRIMS)
       (VALU)
       (setq x (atof (substr Row 1 (- k 1))))
       (TRIMS)
       (if (= Cr " ")
           (SPC)
           (TRIMS)
       (setq h nil s nil)
       (VALU)
       (if (> k 1)
           (if (< (ascii (substr Row 1 1)) 58)
             (setq h (atof (substr Row 1 (- k 1))))
             (setq h nil s (substr Row 1 (- k 1)))
       (TRIMS)
       (if (= Cr " ")
           (SPC)
           (TRIMS)
       (if (and (= s nil) (/= (substr Row 1 1) ""))
           (VALU)
           (setq s (substr Row 1 (- k 1)))
       (setq tc (list y x))
       (WRT)
       (if (/= h nil)
           (WRTH)
       (if (/= s nil)
            (WRTS)
       (COMMAND "LAYER" "S" "0" "")
       (COMMAND "ZOOM" "E" "")
       (prin1)
 (close fr)
;  (close m)
(DEFUN SPC ()
 (setq k 0 Cr " ")
 (while (= Cr " ")
   (setq k (+ k 1))
   (setq Cr (substr Row k 1))
(DEFUN VALU ()
 (setq k 0 Cr "&")
 (while (and (/= Cr " ") (/= Cr ""))
   (setq k (+ k 1))
(DEFUN TRIMS ()
 (setq tmp (substr Row k))
 (setq Row tmp)
(DEFUN WRT ()
 (if (/= s nil)
     (if (or (= (strcase s) "P") (= (strcase s) "T"))
       (setq tn (list y (+ x fnt)))
       (setq tn (list y (+ x dpn)))
 (COMMAND "LAYER" "S" "PNT_CEN" "")
 (COMMAND "POINT" tc)
 (COMMAND "LAYER" "S" "PNT_NUM" "")
 (COMMAND "TEXT" "S" "1" "BC" tn "0" Pn)
(DEFUN WRTH ()
 (if (/= s nil)
       (setq tl (list (+ y fnt) x))
       (setq tl (list (+ y dis) x))
 (setq hs (rtos h 2 2))
 (setq l (strlen hs))
 (setq hs (substr hs 1 l))
 (DEC)
 (setq p (- l k))
;  (cond ((= k l) (setq hs (strcat hs ".00")))
;        ((= (- l 1)) (setq hs (strcat hs "0")))
;  (progn
   (cond ((= p 0) (setq hs (strcat hs ".00")))
         ((= p 1) (setq hs (strcat hs "0")))
 (COMMAND "LAYER" "S" "LEVEL" "")
 (COMMAND "TEXT" "S" "1" "TL" tl "0" hs)
(DEFUN WRTS ()
 (setq ts (list (- y (/ fnt 1.625)) x))
;  (setq ts (list (- y dis) x))
 (COMMAND "LAYER" "S" "SIGN" "")
 (if (= (strcase s) "T" )
   (TRG)
 (if (= (strcase s) "P" )
   (TRP)
 (if (and (/= (strcase s) "P") (/= (strcase s) "T"))
   (COMMAND "TEXT" "S" "1" "MR" ts "0" s)
(DEFUN DEC ()
 (setq k 0 Cr "&" l (strlen hs))
 (while (and (< k l) (/= Cr "."))
   (setq k (+ k 1))
   (setq Cr (substr hs k 1))
(DEFUN TRG ()
;  (setq a (/ (sqrt (/ (expt dia 2) 3)) 2))
 (setq a (sqrt (/ (expt dia 2) 3)))
 (setq b (* a (/ (sin 0.5236) (cos 0.5236))))
;  (setq b (* a (/ (sin 30) (cos 30))))
;  (setq b (* a (/ 1 (atan 0.5236))))
 (setq c (- dia b))
 (setq t1 (list (+ y a) (- x b)))
 (setq t2 (list (- y a) (- x b)))
 (setq t3 (list y (+ x c)))
 (COMMAND "LINE" t1 t2 t3 t1 "")
(DEFUN TRP ()
 (COMMAND "CIRCLE" tc (/ dia 2))
(princ "..!")
(prompt "\rProgram se startuje sa TOPO\007")
(prin1)
