Can you draw a circle use a spline?
cnreader
In most other programs this is no problem, but in AutoCAd version 21(!) it still is :)
  • Replies 44
  • cnreader
    22
  • Raggi_Thor
    15
  • SEANT
    7
  • Pocket
    1
Posted Images
  • 1 year later...
If a circular Spline of degree 2 (order 3) were needed, and Rhino was not available, it could be generated with Autocad by jumping through some hoops.
For example:
Set SPLINETYPE system variable to 5
Command: _polygon Enter number of sides
proceed to make polygon (actually a Polyline) to the approximate size needed
Command: _pedit Select polyline or [Multiple]
select polygon Spline
A Quadratic (degree 2) Spline Fit 2DPolyline is generated.
Command: _spline
choose [Object] option and select 2DPoly
The poly is converted to a circular spline with 8 semi-regularly spaced Control Points. Fit Point data has been purged.
A _scale with [Reference] option may be needed to get the appropriate size.
I’m adding to this thread in case future searches on the subject are presented with imprecise information
The recommendation I made above – though very circle like – deviates from a constant radius by about 1%. Regular polygons with more sides would reduce the error but not eliminate it.
I’ve posted a .NET routine that produces a pure Nurbs circle for AutoCAD in the same fashion as those produced by Rhino and other Nurbs based modelers.
http://www.cadtutor.net/forum/showthread.php?t=32338
Nice, and clever! :D
Thanks. Now if only I could find a legitimate use for it. . . . :)
