maksolino Posted March 12, 2009 Posted March 12, 2009 i'm looking for a lisp routine for intersect spline at coordinate value example 1. select the splines 2. input value of coordinate (x=200 or y=400 or z=1000) result points in drawing Thank you Quote
maksolino Posted March 13, 2009 Author Posted March 13, 2009 i must add that the spline is always perpendicular on some axis (in this case its about ship frames and water lines). Im not at home whith lisp programming but the way to do it can be 1.input value (like z=4000) 1.when select a string it takes a position of the axis 2. draw a perpendicolar line on the axis whit value -100000 +100000 2. find a intersection point between line and spline 3. delete the line 4.draw the point Quote
SEANT Posted March 13, 2009 Posted March 13, 2009 Unfortunately, I don’t know lisp. I did set up a test VBA routine. It only works with one orientation, however, with a target elevation along the Z axis. The routine works best from either a Front or Side view – and a point picked at the desired intersection plane. *Correction: Only works with entities parallel to the Front view* not Side View Limited error checking employed. Sub PointsAtElevation() Dim dblPt(2) As Double Dim ent As AcadEntity Dim entMirror As AcadEntity Dim varMin As Variant Dim varMax As Variant Dim dblThird(2) As Double Dim dblElevation As Double Dim varElevPt As Variant Dim varReturn As Variant Dim intCount As Integer Dim i As Integer Dim entPt As AcadPoint Dim objSS As AcadSelectionSet With ThisDrawing On Error Resume Next .SelectionSets.Item("SSTemp").Delete On Error GoTo 0 Set objSS = .SelectionSets.Add("SSTemp") objSS.SelectOnScreen If objSS.Count < 1 Then Exit Sub varElevPt = .Utility.GetPoint(, "Select target elevation: ") If UBound(varElevPt) <> 2 Then Exit Sub For Each ent In objSS ent.GetBoundingBox varMin, varMax varMin(2) = varElevPt(2) varMax(2) = varElevPt(2) dblThird(0) = varMin(0) dblThird(1) = varMin(1) + 1# dblThird(2) = varMin(2) + 1# Set entMirror = ent.Mirror3D(varMin, varMax, dblThird) varReturn = entMirror.IntersectWith(ent, acExtendNone) intCount = ((UBound(varReturn) + 1) / 3) - 1 For i = 0 To intCount dblPt(0) = varReturn(3 * i) dblPt(1) = varReturn(3 * i + 1) dblPt(2) = varReturn(3 * i + 2) ThisDrawing.ModelSpace.AddPoint (dblPt) Next entMirror.Delete Next End With End Sub Quote
SEANT Posted March 13, 2009 Posted March 13, 2009 I should point out that I'm assuming the Splines are all planar and in parallel planes. Quote
David Bethel Posted March 13, 2009 Posted March 13, 2009 I'd say that it could not be done with plain AutoLISP. I guess my question would be how to deal with multiple intersections of the spline with the given plane. I would think that a full ship frame intersects say the water line in 2 places. -David Quote
SEANT Posted March 13, 2009 Posted March 13, 2009 I'd say that it could not be done with plain AutoLISP. No doubt. I would think that a full ship frame intersects say the water line in 2 places. -David Perhaps even more if the design is a tunnel hull, cat- or trimaran. Quote
maksolino Posted March 16, 2009 Author Posted March 16, 2009 Fisrt thank you for the answer but my exsperience whith vba is very poor and i am not good enough to use the code. Second i wont to add that always we divide the body lines of the ship in left side, right side(almost mirror of left side),fore part and aft part. In this case there is no multiple intersections of the spline. Can somebody make the whole vba or lisp routine ? Greetings Quote
SEANT Posted March 17, 2009 Posted March 17, 2009 Is it possible to post a sample file with the splines set up in a typical configuration? I’m envisioning a oriented 3D layout but guess I don’t know that for certain. In general, an example file is the best way to give full scope to the problem in question. The “full scope” also seems to be the best way to generate interest and enthusiasm within in the resident code writing community. Quote
maksolino Posted March 17, 2009 Author Posted March 17, 2009 sorry that i don't do it before naw i attach one sample file with the splines set up in a typical configuration. I must draw a lot of waterlines and then a lot of frames Frames is in always situated in yz plane and waterlines in xy plane testforma.dwg Quote
Lee Mac Posted March 17, 2009 Posted March 17, 2009 This is probably way off, as I have only caught the end of this thread, but this should find the intersections between your spline and the Polylines. (defun c:SplInt (/ spEnt ss spObj ObjLst iArr ptLst) (if (and (setq spEnt (car (entsel "\nSelect Spline to Retrieve Intersections..."))) (= "SPLINE" (cdadr (entget spEnt))) (setq ss (ssget "X" (list (cons 0 "LWPOLYLINE") (cons 8 "SHP") (if (getvar "CTAB")(cons 410 (getvar "CTAB")) (cons 67 (- 1 (getvar "TILEMODE")))))))) (progn (setq spObj (vlax-ename->vla-object spEnt) ObjLst (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss)))) (foreach Obj ObjLst (setq iArr (vlax-variant-value (vla-IntersectWith spObj Obj acExtendNone))) (if (> (vlax-safearray-get-u-bound iArr 1) 0) (setq ptLst (cons (vlax-safearray->list iArr) ptLst)))) (alert (vl-princ-to-string ptLst))) (princ "\n<!> No Spline Selected or No PLines Found <!>")) (princ)) Quote
SEANT Posted March 18, 2009 Posted March 18, 2009 This is probably way off, as I have only caught the end of this thread, but this should find the intersections between your spline and the Polylines. It is more like the intersection of the poly’s or splines with a plane i.e., where a curve crosses Z = 15000. I have to say it is not an easy task in VBA (without the Curve Functions). I could have tried it in C#, but I have no way of testing .NET code against 2006. Here (and in my original post) I used a Mirror3D and then IntersectWith to get the appropriate intersections. To use load and run PointsAtElevation To run a VBA routine: http://www.cadtutor.net/forum/showthread.php?t=30608 *Edit - Works with AutoCAD 2009 but not 2004. Option Explicit Sub PointsAtElevation() Dim dblPt(2) As Double Dim ent As AcadEntity Dim entMirror As AcadEntity Dim varMin As Variant Dim varMax As Variant Dim dblThird(2) As Double Dim dblElevation As Double Dim varElevPt As Variant Dim varReturn As Variant Dim intCount As Integer Dim i As Integer Dim entPt As AcadPoint Dim objSS As AcadSelectionSet Dim strKeyWordList As String Dim intAxis As Integer Dim strTemp As String Dim dblElev As Double Dim varFilter As Variant Dim strKeyWord As String Dim blnErase As Boolean With ThisDrawing strKeyWordList = "X x Y y Z z" .Utility.InitializeUserInput 1, strKeyWordList On Error Resume Next strKeyWord = .Utility.GetKeyword("Enter axis of interest [X, Y, Z]: ") If Err Then Exit Sub If UCase(strKeyWord) = "X" Then intAxis = 0 ElseIf UCase(strKeyWord) = "Y" Then intAxis = 1 ElseIf UCase(strKeyWord) = "Z" Then intAxis = 2 Else .Utility.Prompt (vbCr & "Invalid input!") Exit Sub End If strKeyWordList = "*" .Utility.InitializeUserInput 128, strKeyWordList varElevPt = .Utility.GetPoint(, "Select target elevation, or input elevation value: ") strTemp = .Utility.GetInput() If UBound(varElevPt) <> 2 Then Err.Clear dblElev = CDbl(strTemp) If Err Then Exit Sub Else dblElev = varElevPt(intAxis) End If On Error GoTo 0 varFilter = LoadFilterArray(intAxis) If SoSSS(varFilter(0), varFilter(1)) > 0 Then For Each ent In .SelectionSets("TempSSet") If TypeOf ent Is AcadLWPolyline Then Set ent = ProcessPoly(ent) blnErase = True End If ent.GetBoundingBox varMin, varMax varMin(intAxis) = dblElev varMax(intAxis) = dblElev dblThird(0) = varMin(0) + 1# dblThird(1) = varMin(1) + 1# dblThird(2) = varMin(2) + 1# Set entMirror = ent.Mirror3D(varMin, varMax, dblThird) varReturn = entMirror.IntersectWith(ent, acExtendNone) intCount = ((UBound(varReturn) + 1) / 3) - 1 For i = 0 To intCount dblPt(0) = varReturn(3 * i) dblPt(1) = varReturn(3 * i + 1) dblPt(2) = varReturn(3 * i + 2) ThisDrawing.ModelSpace.AddPoint (dblPt) Next If blnErase Then ent.Delete: blnErase = False entMirror.Delete Next End If End With End Sub Private Sub SSClear() Dim SSS As AcadSelectionSets Set SSS = ThisDrawing.SelectionSets If SSS.Count > 0 Then Dim objSS As AcadSelectionSet For Each objSS In SSS If objSS.Name = "TempSSet" Then objSS.Delete: Exit Sub Next Else Exit Sub End If End Sub Function SoSSS(Optional grpCode As Variant, Optional dataVal As Variant) As Integer Dim TempObjSS As AcadSelectionSet SSClear Set TempObjSS = ThisDrawing.SelectionSets.Add("TempSSet") 'pick selection set If IsMissing(grpCode) Then TempObjSS.SelectOnScreen Else TempObjSS.SelectOnScreen grpCode, dataVal End If SoSSS = TempObjSS.Count End Function Function LoadFilterArray(intAxis As Integer) As Variant Dim intCode(21) As Integer Dim varData(21) As Variant Dim varArray(1) As Variant Dim dblAxis1(2) As Double Dim dblAxis2(2) As Double Dim dblAxis3(2) As Double Dim dblAxis4(2) As Double dblAxis1((intAxis + 1) Mod 3) = 1# dblAxis2((intAxis + 2) Mod 3) = 1# dblAxis3((intAxis + 1) Mod 3) = -1# dblAxis4((intAxis + 2) Mod 3) = -1# intCode(0) = -4: varData(0) = "<Or" intCode(1) = -4: varData(1) = "<And" intCode(2) = 0: varData(2) = "Spline" 'planar Splines intCode(3) = -4: varData(3) = "&=" intCode(4) = 70: varData(4) = 8 intCode(5) = -4: varData(5) = "<Or" intCode(6) = 210: varData(6) = dblAxis1 intCode(7) = 210: varData(7) = dblAxis2 intCode( = 210: varData( = dblAxis3 intCode(9) = 210: varData(9) = dblAxis4 intCode(10) = -4: varData(10) = "Or>" intCode(11) = -4: varData(11) = "And>" intCode(12) = -4: varData(12) = "<And" intCode(13) = 0: varData(13) = "LWPOLYLINE" 'or LWP's intCode(14) = -4: varData(14) = "<Or" intCode(15) = 210: varData(15) = dblAxis1 intCode(16) = 210: varData(16) = dblAxis2 intCode(17) = 210: varData(17) = dblAxis3 intCode(18) = 210: varData(18) = dblAxis4 intCode(19) = -4: varData(19) = "Or>" intCode(20) = -4: varData(20) = "And>" intCode(21) = -4: varData(21) = "Or>" varArray(0) = intCode varArray(1) = varData LoadFilterArray = varArray End Function Function ProcessPoly(ent As AcadLWPolyline) As Acad3DPolyline Dim dblNormal() As Double Dim varPLCoord As Variant Dim dblCoords() As Double Dim intUbound As Integer Dim i As Integer Dim varDummy As Variant Dim dblElev As Double Dim dblTransfer(2) As Double dblNormal = ent.Normal dblElev = ent.Elevation intUbound = ((UBound(ent.Coordinates) + 1) / 2) - 1 ReDim dblCoords((((intUbound + 1) * 3) - 1)) For i = 0 To intUbound varPLCoord = ent.Coordinate(i) dblTransfer(0) = varPLCoord(0) dblTransfer(1) = varPLCoord(1) dblTransfer(2) = dblElev varPLCoord = ThisDrawing.Utility.TranslateCoordinates(dblTransfer, acOCS, acWorld, 0, dblNormal) dblCoords(i * 3) = varPLCoord(0) dblCoords(i * 3 + 1) = varPLCoord(1) dblCoords(i * 3 + 2) = varPLCoord(2) Next Set ProcessPoly = ThisDrawing.ModelSpace.Add3DPoly(dblCoords) End Function Quote
SEANT Posted March 18, 2009 Posted March 18, 2009 Here's a 2004 compatible version. Apparently VBA support for Normals of Planar Splines was not available back in 2004. This routine (AC2004Compatible.txt) employs a different approach. One additional note, both this and the routine posted previously handle only LightWeightPolys and/or Planar Splines. Edit: See updated code http://www.cadtutor.net/forum/showpost.php?p=222822&postcount=22 Quote
Lee Mac Posted March 18, 2009 Posted March 18, 2009 Ahh, maybe the code I posted was not the best suited then I had a look at using the curve functions in VL, but couldn't think how to get a point on the curve at some user defined elevation without using some iterative process by which one would move along the curve at small intervals until you get close enough by some tolerance to the required elevation I didn't like this method and so didn't pursue it. Quote
Lee Mac Posted March 18, 2009 Posted March 18, 2009 You mention that you used "mirror3d" followed by "intersectWith", just curious (and I am not too conversant with VBA), how did the "mirror3d" come into it Thanks Lee Quote
SEANT Posted March 18, 2009 Posted March 18, 2009 The OP stated that all the Curves in question would be planar and aligned to one of the three main orthographic planes. Because of that a Bounding Box call will return essentially a planar expanse and, if the target elevation is substituted for the appropriate coordinate of min and max, it would create a nice line across the curve. My original notion was to use that line to IntersectWith the curve. For some reason (which I have yet to figure out) that was not giving me any intersections. For the hell of it, I tried to use identical entities, and figured one was readily available if I 3Dmirrored the original curve about that elevation line and calc’ed point (see Sample). Those intersect well enough. MirrorIntersect.dwg Quote
Lee Mac Posted March 18, 2009 Posted March 18, 2009 Ahh, I see - so how I understand it is that "intersectwith" seems to only work in the x-y plane. Thats funny, because, if you try my posted LISP to find the intersections between the splines and the polylines in the OP's posted drawing, it returns nil until you try it on a spline and pline in the x-y plane. Lee PS> Great example drawing - well drafted. Quote
SEANT Posted March 18, 2009 Posted March 18, 2009 IntersectWith does seem a bit spotty. The same mirror method does not work with Lightweight polylines. * I guess with polylines, in particular, their planar quality is virtually a core component of their entity type. It sort of makes sense that their implementation of IntersectWith is extremely sensitive to common planes. Have you tried IntersectWith between a poly and spline on a common plane other than WCS’s XY? It may work if they were both on the XZ, for instance. Splines are not required to be planar, thus may have gotten a little more attention from the boys at Autodesk with regard to intersections between planes. * I had to provide a conversion to splines to get my routine to work with LWPolys. In fact, if the polys are too coarse, there may be significant error to the calculated elevation points. Quote
Lee Mac Posted March 19, 2009 Posted March 19, 2009 Ahh good thinking Sean, they may have only accommodated intersecting Plines within the same plane. Tbh, I haven't spent much time on the IntersectWith method ~ I wrote a couple of LISPs a while back though, just messing around with it, could be worth some experimentation with them to see where we stand (defun ssInter (ss / i y Ent1 Ent2 iArr iLst) (setq i (sslength ss)) (while (not (minusp (setq y (1- i) i (1- i)))) (setq Ent1 (vlax-ename->vla-object (ssname ss i))) (while (not (minusp (setq y (1- y)))) (setq Ent2 (vlax-ename->vla-object (ssname ss y)) iArr (vlax-variant-value (vla-IntersectWith Ent1 Ent2 acExtendNone))) (if (> (vlax-safearray-get-u-bound iArr 1) 0) (progn (setq iLst (vlax-safearray->list iArr)) (while (not (zerop (length iLst))) (setq ptLst (cons (list (car iLst) (cadr iLst) (caddr iLst)) ptLst) iLst (cdddr iLst)))))))) (defun c:test (/ ptLst) (vl-load-com) (ssInter (ssget)) (alert (vl-princ-to-string ptLst)) (princ)) (defun ssInter (ss / vLst i j obj1 obj2 iArr iLst) (setq vLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) i (length vLst)) (while (not (minusp (setq j (1- i) i (1- i)))) (setq obj1 (nth i vLst)) (while (not (minusp (setq j (1- j)))) (setq obj2 (nth j vLst) iArr (vlax-variant-value (vla-IntersectWith obj1 obj2 acExtendNone))) (if (> (vlax-safearray-get-u-bound iArr 1) 0) (progn (setq iLst (vlax-safearray->list iArr)) (while (not (zerop (length iLst))) (setq ptLst (cons (list (car iLst) (cadr iLst) (caddr iLst)) ptLst) iLst (cdddr iLst)))))))) (defun c:test (/ ptLst) (vl-load-com) (ssInter (ssget)) (alert (vl-princ-to-string ptLst)) (princ)) They both do pretty much the same thing - find all intersections in a selection set. But the second approach the selection set as a list of entities, whereas the first just hits the set head on. I was just experimenting with different ways to accomplish the same goal - could be useful though, for testing with IntersectWith. Cheers Lee Quote
SEANT Posted March 19, 2009 Posted March 19, 2009 Nice. Those will help determine where and when intersections can be acquired. Now that we’ve talked about it, I wonder if 3DPoly’s are more or less capable of finding Intersections. Next time I’m in front of AutoCAD, I’ll use your routine to test them. That alternative may help me reduce the Spline induced error I mentioned previously. Quote
Lee Mac Posted March 19, 2009 Posted March 19, 2009 Nice. Those will help determine where and when intersections can be acquired. Now that we’ve talked about it, I wonder if 3DPoly’s are more or less capable of finding Intersections. Next time I’m in front of AutoCAD, I’ll use your routine to test them. That alternative may help me reduce the Spline induced error I mentioned previously. I feel honoured Quote
