Dave^ Posted March 11, 2009 Share Posted March 11, 2009 is there an easy, single-click option to select all the ductwork in a run without picking every piece? i have a tonne of pieces in a long run which i need to move, and selecting each piece will be a pain.... there are other duct runs and services so i can't just select the whole run with select box.... cadduct version 2.37.172..... tia Quote Link to comment Share on other sites More sharing options...
Le Teace Posted March 24, 2009 Share Posted March 24, 2009 is there an easy, single-click option to select all the ductwork in a run without picking every piece? i have a tonne of pieces in a long run which i need to move, and selecting each piece will be a pain.... there are other duct runs and services so i can't just select the whole run with select box.... cadduct version 2.37.172..... tia Try typing SL1 or SL2 One isolates a service, the other hides a service (can't remember which is which). Type SHOWALL to turn all the parts back on after moving your parts. This depends how well yo have used services. HTH Quote Link to comment Share on other sites More sharing options...
