New programmer asks:
Starting out with baby steps, I am attempting to set the LTSCALE for a couple hundred drawings as I edit them.
PROGRAM
(defun c:LT ()
(command "LTSCALE" 4.25 )
(c:LT)
Right now, the command line returns:
: (load "lt")
: LTSCALE
New current value for LTSCALE (greater than zero) <9.5>: 4.25nil
QUESTION: How do I add a comment in the command line when the code is finished that will read "LTSCALE set to 4.25" ?
Edited by Clint
Clarification
PROGRAM
(defun c:LT ()
(c:LT)
: (load "lt")
: LTSCALE
Do it like this:
(defun c:lt nil
    (princ (strcat "LTSCALE set to " (rtos (setvar "ltscale" 4.25) 2)))
Jonathan,
Thanks for your reply and the improved code😀
Clint
There is a very advanced method using a reactor can type L4-25 and the ltscale will be set to that, L10, l2 etc. It uses an error trap in a reactor as what is typed does not exist so an error occurs, I currently have Circle, Offset and Fillet using this. You are limited to 26 options  ie A-Z. C10 O5 F23
So in summing up if you have lots of ltscale to use could be helpful. Just ask.
BIGAL,
Sure! I would like to check out the reactor-based code.
Make it available at your earliest convenience.
Thanks,
Clint
