samifox Posted April 20 Share Posted April 20 hi im trying to write a lisp that -ask user to select objects and capture them - invoke the boundary command so user can pick point - capture the new object generated deletes the old objects the lisp yell this error, ; error: bad argument type: VLA-OBJECT nil i can't debug since the breakpoint is ignored. any idea? (defun c:br (/ original_objects new_boundary) (setq original_objects (ssget '((0 . "*LINE")))) (if (and original_objects (> (sslength original_objects) 0));; if selected (progn (command "-BOUNDARY") (setq new_boundary (entlast)) (repeat (sslength original_objects) (vla-delete (vlax-ename->vla-object (ssname original_objects 0))) ) (princ "\nBoundaries created and original polylines replaced.") ) (princ "\nNo polylines found to replace.") ) (princ) Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted April 20 Share Posted April 20 (edited) I've changed just slightly your code, but untested I think that it should work... (defun c:br ( / original_objects new_boundary k e ) (setq original_objects (ssget "_:L" (list (cons 0 "*LINE")))) (if (and original_objects (> (sslength original_objects) 0));; if selected (progn (initdia) (command "_.BOUNDARY") (while (< 0 (getvar (quote cmdactive))) (command "\\") ) (setq new_boundary (entlast)) (setq k -1) (repeat (sslength original_objects) (if (and (setq e (ssname original_objects (setq k (1+ k)))) (not (vlax-erased-p e))) (entdel e) ) ) (princ "\nBoundaries created and original polylines replaced.") ) (princ "\nNo polylines found to replace.") ) (princ) ) HTH. M.R. Edited April 21 by marko_ribar Quote Link to comment Share on other sites More sharing options...
