Engineer_Yasser Posted April 16 Posted April 16 (edited) I have list ( (<Entity name: 21b0e473810> . "R-4-2-16.00") (<Entity name: 21b0e473a90> . "R-11-16.00") (<Entity name: 21b7741fd90> . "CL-2-18.00") (<Entity name: 21b0e473910> . "R-8-16.00") (<Entity name: 21b7741fd10> . "CL-17-20.00") (<Entity name: 21b0e473990> . "R-9-20.00") (<Entity name: 21b7741fe90> . "R-4-1-16.00") (<Entity name: 21b7741ff10> . "R-4-1-20.00") (<Entity name: 21b0e473890> . "R-7-20.00") (<Entity name: 21b7741fe10> . "R-4-15.00") (<Entity name: 21b0e473a10> . "R-10-20.00") (<Entity name: 21b0e473b10> . "R-1-20.00") ) I want to be sorted out like ( (<Entity name: 21b7741fd90> . "CL-2-18.00") (<Entity name: 21b7741fd10> . "CL-17-20.00") (<Entity name: 21b0e473b10> . "R-1-20.00") (<Entity name: 21b7741fe10> . "R-4-15.00") (<Entity name: 21b7741fe90> . "R-4-1-16.00") (<Entity name: 21b7741ff10> . "R-4-1-20.00") (<Entity name: 21b0e473810> . "R-4-2-16.00") (<Entity name: 21b0e473890> . "R-7-20.00") (<Entity name: 21b0e473910> . "R-8-16.00") (<Entity name: 21b0e473990> . "R-9-20.00") (<Entity name: 21b0e473a10> . "R-10-20.00") (<Entity name: 21b0e473a90> . "R-11-16.00") ) when I tried vl-sort i didn't get the correct result Edited April 16 by Engineer_Yasser Quote
Lee Mac Posted April 16 Posted April 16 (edited) In the comparison function supplied to vl-sort, split the cdr of each dotted pair using the hyphen as a delimiter and then compare each element. Or, alternatively (and likely more performant), sort a version of the list (which has already been tokenised) using vl-sort-i and then use mapcar to sort the original list. Edited April 16 by Lee Mac Quote
mhupp Posted April 16 Posted April 16 Im guessing your sort looked something like this? you need to add 0's to the single digit numbers (<Entity name: 21b7741fd10> . "CL-17-20.00") (<Entity name: 21b7741fd90> . "CL-2-18.00") (<Entity name: 21b0e473b10> . "R-1-20.00") (<Entity name: 21b0e473a10> . "R-10-20.00") (<Entity name: 21b0e473a90> . "R-11-16.00") (<Entity name: 21b7741fe10> . "R-4-15.00") (<Entity name: 21b7741fe90> . "R-4-1-16.00") (<Entity name: 21b7741ff10> . "R-4-1-20.00") (<Entity name: 21b0e473810> . "R-4-2-16.00") (<Entity name: 21b0e473890> . "R-7-20.00") (<Entity name: 21b0e473910> . "R-8-16.00") (<Entity name: 21b0e473990> . "R-9-20.00") this will add 0's but your going to have to split up the string to do it then strcat it back together. https://www.cadtutor.net/forum/topic/78351-help-with-routinenumerical-filter/?do=findComment&comment=623332 (AT:NumFix num 2) (<Entity name: 21b7741fd90> . "CL-02-18.00") (<Entity name: 21b7741fd10> . "CL-17-20.00") ... (<Entity name: 21b0e473b10> . "R-01-20.00") (<Entity name: 21b7741fe10> . "R-04-15.00") ... (<Entity name: 21b0e473a10> . "R-10-20.00") (<Entity name: 21b0e473a90> . "R-11-16.00") Quote
Lee Mac Posted April 16 Posted April 16 9 minutes ago, Lee Mac said: Or, alternatively (and likely more performant), sort a version of the list (which has already been tokenised) using vl-sort-i and then use mapcar to sort the original list. Perhaps something like this - (defun sortit ( lst ) (mapcar '(lambda ( n ) (nth n lst)) (vl-sort-i (mapcar '(lambda ( x ) (LM:str->lst (cdr x) "-")) lst) (function (lambda ( a b / x y ) (while (and a b (= (car a) (car b))) (setq a (cdr a) b (cdr b) ) ) (cond ( (null a)) ( (null b) nil) ( (and (numberp (setq x (read (car a)))) (numberp (setq y (read (car b)))) ) (< x y) ) ( (numberp x)) ( (numberp y) nil) ( (< (car a) (car b))) ) ) ) ) ) ) ;; String to List - Lee Mac ;; Separates a string using a given delimiter ;; str - [str] String to process ;; del - [str] Delimiter by which to separate the string ;; Returns: [lst] List of strings (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) 1 Quote
Engineer_Yasser Posted April 16 Author Posted April 16 19 minutes ago, mhupp said: Im guessing your sort looked something like this? you need to add 0's to the single digit numbers (<Entity name: 21b7741fd10> . "CL-17-20.00") (<Entity name: 21b7741fd90> . "CL-2-18.00") (<Entity name: 21b0e473b10> . "R-1-20.00") (<Entity name: 21b0e473a10> . "R-10-20.00") (<Entity name: 21b0e473a90> . "R-11-16.00") (<Entity name: 21b7741fe10> . "R-4-15.00") (<Entity name: 21b7741fe90> . "R-4-1-16.00") (<Entity name: 21b7741ff10> . "R-4-1-20.00") (<Entity name: 21b0e473810> . "R-4-2-16.00") (<Entity name: 21b0e473890> . "R-7-20.00") (<Entity name: 21b0e473910> . "R-8-16.00") (<Entity name: 21b0e473990> . "R-9-20.00") this will add 0's but your going to have to split up the string to do it then strcat it back together. https://www.cadtutor.net/forum/topic/78351-help-with-routinenumerical-filter/?do=findComment&comment=623332 (AT:NumFix num 2) (<Entity name: 21b7741fd90> . "CL-02-18.00") (<Entity name: 21b7741fd10> . "CL-17-20.00") ... (<Entity name: 21b0e473b10> . "R-01-20.00") (<Entity name: 21b7741fe10> . "R-04-15.00") ... (<Entity name: 21b0e473a10> . "R-10-20.00") (<Entity name: 21b0e473a90> . "R-11-16.00") Thanks For Help 1 Quote
Engineer_Yasser Posted April 16 Author Posted April 16 8 minutes ago, Lee Mac said: Perhaps something like this - (defun sortit ( lst ) (mapcar '(lambda ( n ) (nth n lst)) (vl-sort-i (mapcar '(lambda ( x ) (LM:str->lst (cdr x) "-")) lst) (function (lambda ( a b / x y ) (while (and a b (= (car a) (car b))) (setq a (cdr a) b (cdr b) ) ) (cond ( (null a)) ( (null b) nil) ( (and (numberp (setq x (read (car a)))) (numberp (setq y (read (car b)))) ) (< x y) ) ( (numberp x)) ( (numberp y) nil) ( (< (car a) (car b))) ) ) ) ) ) ) ;; String to List - Lee Mac ;; Separates a string using a given delimiter ;; str - [str] String to process ;; del - [str] Delimiter by which to separate the string ;; Returns: [lst] List of strings (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) Perfect Solution .. You are Genius Quote
