Hi,
I am having quite a number of difficulty with importing and creating contour lines from an Autocad file.  I believe I have transfer the contour lines correctly but its position as per elevation is definitely incorrect. Perhaps it is due to the view range cut offset. I have watch a tutorial where the top should be set to "unlimited" and the cut to a figure above the highest elevation which is 17m. Thanks in advance for your help. Any supplementary information. Please let me know. I have attached the revit file.  If you need the cad file. let me know.
856-REVIT_003.rvt
Your profile says 2015 but is this a Revit question ? I can not help.
