Good afternoon
I really need to have a lisp routine that:
- Let me select a main block
- answer for the prefix to rename all nested blocks
- rename all nested blocks in the block i selected and keep the name of the "main block" equal (without rename).
I found this routine here in the forum (thanks to who posted) but also renames the main block and i dont know how to change it...
(defun c:rnb (/ getNestedNames remove_duplicates ss n ent name lst)
(vl-load-com)
(or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object))))
(or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*)))
;; Returns a list of the nested block names
(defun getNestedNames (name / lst)
(vlax-for o (vla-Item *blocks* name)
(if (= (vla-get-ObjectName o) "AcDbBlockReference")
(setq lst (append (list (vla-get-Name o))
(getNestedNames (vla-get-Name o))
lst
lst
;; Removes all duplicates from a list
(defun remove_duplicates (lst)
(if lst
(cons (car lst) (remove_duplicates (vl-remove (car lst) lst)))
;; Main
(if (setq pref (getstring "\nEnter the prefix to add: "))
(vla-StartUndoMark *acdoc*)
(princ "\Select bloc to rename (or Enter for all)")
(if (ssget '((0 . "INSERT")))
;; selection
(vlax-for b (setq ss (vla-get-ActiveSelectionSet *acdoc*))
(setq name (vla-get-name b))
(if (not (vl-position name lst))
(setq lst (append (list name) (getNestedNames name) lst))
(vla-delete ss)
(foreach n (remove_duplicates lst)
(vla-put-Name (vla-item *blocks* n) (strcat pref n))
;; all
(vlax-for b *blocks*
(if (and
(= (vla-get-IsLayout b) :vlax-false)
(= (vla-get-IsXref b) :vlax-false)
(not (wcmatch (setq name (vla-get-Name b)) "*|*"))
(vla-put-Name b (strcat pref name))
(vla-EndUndoMark *acdoc*)
Thanks in advance
Edited by SLW210
Added Code Tags
Please use Code Tags in the future. (the <> in the editor toolbar)
Thanks SLW210.
I''ll keep that in mind for the next time
@mike_ribeiroTry commenting out the following lines:
;; (if (not (vl-position name lst))
;; (setq lst (append (list name) (getNestedNames name) lst))
EDIT - AND add this line right below the commented lines
(setq lst (getNestedNames name))
Edited by pkenewell
Thanks pkenewell !!!
It works perfect.
