mike_ribeiro Posted April 9 Posted April 9 (edited) Good afternoon I really need to have a lisp routine that: - Let me select a main block - answer for the prefix to rename all nested blocks - rename all nested blocks in the block i selected and keep the name of the "main block" equal (without rename). I found this routine here in the forum (thanks to who posted) but also renames the main block and i dont know how to change it... (defun c:rnb (/ getNestedNames remove_duplicates ss n ent name lst) (vl-load-com) (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object)))) (or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*))) ;; Returns a list of the nested block names (defun getNestedNames (name / lst) (vlax-for o (vla-Item *blocks* name) (if (= (vla-get-ObjectName o) "AcDbBlockReference") (setq lst (append (list (vla-get-Name o)) (getNestedNames (vla-get-Name o)) lst ) ) ) ) lst ) ;; Removes all duplicates from a list (defun remove_duplicates (lst) (if lst (cons (car lst) (remove_duplicates (vl-remove (car lst) lst))) ) ) ;; Main (if (setq pref (getstring "\nEnter the prefix to add: ")) (progn (vla-StartUndoMark *acdoc*) (princ "\Select bloc to rename (or Enter for all)") (if (ssget '((0 . "INSERT"))) ;; selection (progn (vlax-for b (setq ss (vla-get-ActiveSelectionSet *acdoc*)) (setq name (vla-get-name b)) (if (not (vl-position name lst)) (setq lst (append (list name) (getNestedNames name) lst)) ) ) (vla-delete ss) (foreach n (remove_duplicates lst) (vla-put-Name (vla-item *blocks* n) (strcat pref n)) ) ) ;; all (vlax-for b *blocks* (if (and (= (vla-get-IsLayout b) :vlax-false) (= (vla-get-IsXref b) :vlax-false) (not (wcmatch (setq name (vla-get-Name b)) "*|*")) ) (vla-put-Name b (strcat pref name)) ) ) ) (vla-EndUndoMark *acdoc*) ) ) (princ) ) Thanks in advance Edited April 9 by SLW210 Added Code Tags Quote
SLW210 Posted April 9 Posted April 9 Please use Code Tags in the future. (the <> in the editor toolbar) Quote
mike_ribeiro Posted April 10 Author Posted April 10 Thanks SLW210. I''ll keep that in mind for the next time Quote
pkenewell Posted April 10 Posted April 10 (edited) @mike_ribeiroTry commenting out the following lines: ;; (if (not (vl-position name lst)) ;; (setq lst (append (list name) (getNestedNames name) lst)) ;; ) EDIT - AND add this line right below the commented lines (setq lst (getNestedNames name)) Edited April 10 by pkenewell Quote
