hi
im trying to repeat FS command in macro using:
*^C^Cfs
it results with endless loop
whats wrong?
Thanks
S
Not sure what is FS use full name.
Maybe a typo ^C^Cfs
BIGAL, FS = Fast Select
OP, What exactly are you trying to do?
  • 1 month later...
No, that isn't a typo. Starting a command name with a star will cause the command to repeat.
That macro should work. Maybe you just used it in a wrong way?
Working in AutoCAD, you can first select some objects and after that select a command, meaning what do you wish to do with those selected objects.
For simplicity, let's say that you wish to start the Move command.
There are many ways to make a selection set, using FS is one of them.
To use the FS command like that, start the macro you wrote. Select a "touching object", select an other "touching object" (because the FS repeats itself), and again... until the selection is complete. At that point, having objects selected, click the icon for the Move command. It first stops any other running command (that's the role of the ^C^C at the beginning). So that will stop the macro, -but those objects will remain selected- and the Move command will be started. Because already are objects selected, there will be no "select objects" prompt.
Probable the "noun/verb selection" must be enabled, you should right-click in the command line, go to Options, than Select tab and Selection modes to verify that.
