masterfal Posted April 5, 2024 Posted April 5, 2024 Hi All, I have this little lisp routine i run for creating revision clouds. I have it set up so i can turn any closed polyline object into my preset cloud layer with correct arc lengths etc. After its run it always changes my current layer to the one specified in the code below (rev 000 all) and i'd rather it not do that. I know the code is 'setting' the layer first, not sure how to amend so i can switch back to previous layer. Or if keeping current layer isn't easy, switching to layer '0' at the end would also be handy.. Any help greatly appreciated! (defun c:rc () (command "-LAYER" "S" "rev 000 all" "tr" "50" "" "" "revcloud" "A" "700" "700" "o" pause "")) Quote
Jonathan Handojo Posted April 5, 2024 Posted April 5, 2024 Use a variable to store your current layer first. Get it using getvar and setvar: (defun c:rc ( / ly) (setq ly (getvar "clayer")) (command "-LAYER" "S" "rev 000 all" "tr" "50" "" "" "revcloud" "A" "700" "700" "o" pause "") (setvar "clayer" ly) (princ) ) 1 Quote
masterfal Posted April 5, 2024 Author Posted April 5, 2024 thats absolutely perfect.. i love this place. you guys are so unbelievably helpful. cadtutor community ftw!! Quote
