Hi all,
i got quite a large script,
but at this part:
(setvar "CTAB" "Model")
    (command "UCS" "W")
    (command "PLAN" "")
Model is activated, UCS is set to world, but AutoCAD refuses to PLAN te screen.....
Is this a know issue and is there a workaround available?
If not...
How can i detect is the current view is not world?
UCSXDIR and UCSYDIR are showing the expected values, even if the screen is rotated.
13 minutes ago, Aftertouch said:
How about
(command "_UCS" "_wo" "_PLAN" "")
I used (command "PLAN" "") to switch from a non-world UCS to world, and it worked. It wasn't in a function, though. Is it possible that you need to run a Regen as well?
25 minutes ago, Aftertouch said:
 (command "PLAN" "")
@Aftertouch - Perhaps (command "._PLAN" "_W") ?
@CyberAngel thanks, a simple 'REGENALL' solved the issue...
Took me a few hours 😂
