Aftertouch Posted April 4 Posted April 4 Hi all, i got quite a large script, but at this part: (setvar "CTAB" "Model") (command "UCS" "W") (command "PLAN" "") Model is activated, UCS is set to world, but AutoCAD refuses to PLAN te screen..... Is this a know issue and is there a workaround available? If not... How can i detect is the current view is not world? UCSXDIR and UCSYDIR are showing the expected values, even if the screen is rotated. Quote
Least Posted April 4 Posted April 4 13 minutes ago, Aftertouch said: How about (command "_UCS" "_wo" "_PLAN" "") Quote
CyberAngel Posted April 4 Posted April 4 I used (command "PLAN" "") to switch from a non-world UCS to world, and it worked. It wasn't in a function, though. Is it possible that you need to run a Regen as well? 1 Quote
pkenewell Posted April 4 Posted April 4 25 minutes ago, Aftertouch said: (command "PLAN" "") @Aftertouch - Perhaps (command "._PLAN" "_W") ? Quote
Aftertouch Posted April 5 Author Posted April 5 @CyberAngel thanks, a simple 'REGENALL' solved the issue... Took me a few hours Quote
