;; ÐO GÓC 3D free lisp from cadviet.com
(defun c:GH (/ p1 p2 p3 v1 v2 angrad angdeg)
  (setq    p1     (getpoint "\nPick point common to both lines.")
    p2     (getpoint p1 "\nPick end of first line.")
    p3     (getpoint p1 "\nPick end of second line.")
    v1     (uvec (mapcar '- p2 p1))
    v2     (uvec (mapcar '- p3 p1))
    angrad (@acos (dot v1 v2))
    angdeg (/ (* angrad 180.) 3.14159265359)
  (princ "\nAngle between the two lines (degrees): ")
  (princ angdeg)
Error when running: Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Please help me fix this error. Only when used on autocad 2021 does it happen. Thank you
123.lsp
Edited by SLW210
Added CodeTags!
Please use Code Tags in the future. (use the <> in the editor toolbar)
Sorry to bother everyone. The error occurred because I copied the missing lisp
@dungcan68 The error you are describing could not be coming from the code you have presented, but rather an global error handler made by some other additional code not included in what you have shown. The error itself comes from using the (command) function within an error handler, which causes some issues in newer versions of AutoCAD. the (command-s) function was created to allow command functions from within an error handler when referencing local variables, but older code that was not upgraded may display this error.
I recommend you start looking through other AutoLISP functions you have loaded to determine which code is using a global error handler that contains the (command) function.
See the following link for more info:
https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-5C9DC003-3DD2-4770-95E7-7E19A4EE19A1
As pkenewell, I think the issue is in the other LISPs, one of these:
uvec
@acos
dot
