Shib Sankar Posted March 29, 2024 Posted March 29, 2024 Hi experts , good morning and happy good fryday. Hope you're doing well, I'm looking for a lisp routine which can generate blocks considering some logic.. i have attached a AutoCAD.dwg file pls help.. LISP MAKING.dwgFetching info... Quote
BIGAL Posted April 1, 2024 Posted April 1, 2024 (edited) It can be done fairly simply but it needs your help, as the objects are on same layer this complicates things so 1st step is change dims to a new layer, 2nd step change plines to a new layer. Once this is done can just isolate 2 layers the text and the pline. Its a simple look for text say ST1 then search above it for a pline, can then simply block that object with correct name. So try editing the dwg making common objects on layers and code will be easy to do. Re post new dwg. If you want as blocks why not draw correct 1st up I would use a lisp to draw looks like 2 patterns, a triangle and a chamfered corner rectang, can do which way up and which corner pretty easy. As part of lisp makes block. The dwg should really be using lots of layers not everything on layer 0. But I would have lisps for a lot of what your drafting like slots. They could be dynamic blocks, width and length, bolt holes patterns and so much more. Edited April 1, 2024 by BIGAL 1 Quote
Shib Sankar Posted April 9, 2024 Author Posted April 9, 2024 Hi bigal, thanks for your valuable reply... For your information i have re layerd items and make a example of output also.. Pls look into the attachment.. i believe you'll definately find a way LISP MAKING R1 .dwgFetching info... Quote
BIGAL Posted April 11, 2024 Posted April 11, 2024 (edited) This is very rough, would do a dcl with all options in one. Just makes rectangs ,triangle and champher corner. ; https://www.cadtutor.net/forum/topic/82771-export-part-of-drawing-as-dxf-with-individual-name-from-texts/ (defun c:gussets ( / ah:getval ah:rect ah:triangle oldsnap len len2 wid wid2 cham cham2 sc ans) (defun AH:getval ( / ans) (setq vals (AH:getvalsm (list "Enter Values" "Length " 5 4 "250" "Width" 5 4 "100" "Champfer" 5 4 "50" "Scale up" 5 4 "2"))) (setq len (atof (nth 0 vals)) wid (atof (nth 1 vals)) cham (atof (nth 2 vals)) sc (atof (nth 3 vals))) (setq len2 (* sc len) wid2 (* sc wid) cham2 (* sc cham)) ) (defun AH:rect ( / pt1 pt2 ) (setq pt1 (getpoint "\nPick lower left point ")) (AH:getval) (setq pt2 (mapcar '+ pt1 (list len2 wid2 0.0))) (command "rectang" pt1 pt2) (command "dim" "VER" pt1 (mapcar '+ pt1 (list 0.0 wid2 0.0)) (mapcar '+ pt1 (list -70 wid2 0.0)) wid "exit") (command "dim" "Hor" pt1 (mapcar '+ pt1 (list len2 0.0 0.0)) (mapcar '+ pt1 (list 0.0 -100.0 0.0)) len "exit") (princ) ) (defun AH:RectChampher ( / pt1 pt2 pt3 pt4 pt5) (AH:getval) (setq pt1 (getpoint "\nPick lower left point ")) (setq pt2 (mapcar '+ pt1 (list len2 0.0 0.0))) (setq pt3 (mapcar '+ pt2 (list 0.0 (- wid2 cham2) 0.0))) (setq pt5 (mapcar '+ pt1 (list 0.0 wid2 0.0))) (setq pt4 (mapcar '+ pt5 (list (- len2 cham2) 0.0 0.0))) (command "pline" pt1 pt2 pt3 pt4 pt5 "c") (command "dim" "VER" pt1 pt2 (mapcar '+ pt1 (list -70 wid2 0.0)) wid "exit") (command "dim" "Hor" pt1 (mapcar '+ pt1 (list len2 0.0 0.0)) (mapcar '+ pt1 (list 0.0 -100.0 0.0)) len "exit") (command "dim" "Hor" pt4 pt3 (mapcar '+ pt4 (list 0.0 100.0 0.0)) cham "exit") (command "dim" "VER" pt3 pt4 (mapcar '+ pt3 (list 100 0.0 0.0)) cham "exit") (princ) ) (defun AH:triangle ( / pt1 pt2 pt3 ) (setq pt1 (getpoint "\nPick lower left point ")) (AH:getval) (setq pt2 (mapcar '+ pt1 (list len2 0.0 0.0))) (setq pt3 (mapcar '+ pt1 (list 0.0 wid2 0.0))) (command "pline" pt1 pt2 pt3 "c") (command "dim" "VER" pt1 (mapcar '+ pt1 (list 0.0 wid2 0.0)) (mapcar '+ pt1 (list -70 wid2 0.0)) wid "exit") (command "dim" "Hor" pt1 (mapcar '+ pt1 (list len2 0.0 0.0)) (mapcar '+ pt1 (list 0.0 -100.0 0.0)) len "exit") (princ) ) ;;;; starts here (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (if (not AH:Butts)(load "Multi Radio buttons.lsp")) (setq ans (ah:butts 1 "V" '("Please choose " "Plain rectang" "Rect-Chamfer" "Triangle"))) (command "dimstyle" "R" "Copy of DIM-40A") (cond ((= ans "Plain rectang")(AH:rect)) ((= ans "Rect-Chamfer")(AH:RectChampher)) ((= ans "Triangle")(AH:triangle)) ) (setvar 'osmode oldsnap) (princ) ) (c:gussets) There is so much more like hole patterns slots etc that could be generated easily. Multi radio buttons.lspFetching info... Multi GETVALS.lspFetching info... Edited April 11, 2024 by BIGAL Quote
