Shib Sankar Posted March 29, 2024 Posted March 29, 2024 Can anyone help? I'm using autocad 2024 and i need smart block feature which is available with autocad 2025, cmd name is bconvert.. Pls see this YouTube video if required Quote
marko_ribar Posted March 29, 2024 Posted March 29, 2024 I think you are searching BricsCAD command BLOCKIFY, but for AutoCAD... I made it in *.VLX formats block routines among where is also (c:blockify) command function... Here is link, but you have to be logged to be able to download made *.VLX files... https://www.theswamp.org/index.php?topic=55186.msg594547#msg594547 HTH. M.R. Quote
Shib Sankar Posted March 29, 2024 Author Posted March 29, 2024 Mmm thanks i went with the blockify.vlx file but its not working with closed polyline i also have exploded but your blockify.vlx isn't like blockify of bricscad or AutoCAD 2025.. Can u help with any updated one?? Which includes all items i select.. Thanks in advance Quote
Shib Sankar Posted March 29, 2024 Author Posted March 29, 2024 2 hours ago, marko_ribar said: I think you are searching BricsCAD command BLOCKIFY, but for AutoCAD... I made it in *.VLX formats block routines among where is also (c:blockify) command function... Here is link, but you have to be logged to be able to download made *.VLX files... https://www.theswamp.org/index.php?topic=55186.msg594547#msg594547 HTH. M.R. Its saying bad argument type: 2d/3d point nill Quote
marko_ribar Posted March 29, 2024 Posted March 29, 2024 (edited) Describe exact procedure you tried... And provide *.DWG cleaned from things you don't want to show in public... Edited March 29, 2024 by marko_ribar Quote
