NanGlase Posted March 26, 2024 Posted March 26, 2024 Can anyone help to restore the top bar menu of AutoCAD 2014? It is not visible. Quote
SLW210 Posted March 26, 2024 Posted March 26, 2024 That's called the Quick Access Toolbar (QAT) if that helps. What are your computer specifications? What Windows version? What happened that made it disappear? If I recall correctly, this was an issue with running older AutoCAD versions on Windows 10 or newer, I believe AutoCAD 2016 was first for Windows 10. 1 Quote
NanGlase Posted March 26, 2024 Author Posted March 26, 2024 (edited) 11th Gen Intel 64 bit os win10 ver 22h2 i dont remember when it was started to disappear but the very first installation looked good. Edited March 26, 2024 by NanGlase Quote
SLW210 Posted March 26, 2024 Posted March 26, 2024 Probably a Windows update messed it up. You might try a repair, restore to defaults or a remove and reinstall of AutoCAD or get a newer version designed to run with Windows 10. 1 Quote
