Hi all , I'm stuck here .
Given start and end line points as VARIANTS how to make the new pline
(defun lines-as-plines-by-vl ()
  (VL-LOAD-COM)
  (SETQ ACAD-OBJ (VLAX-GET-ACAD-OBJECT)) ;_ el programa ACAD
  (SETQ ADOC (VLA-GET-ACTIVEDOCUMENT ACAD-OBJ)) ;_ el DWG que esta abierto-
  (SETQ MODEL (VLA-GET-MODELSPACE ADOC))
  (setq line-ent (ssname (ssget "_:S+." '((0 . "line"))) 0))
  (Setq line-obj (VLAX-ENAME->VLA-OBJECT line-ent))
  (setq st-point (VLA-GET-STARTPOINT line-obj))
  (setq en-point (VLA-GET-ENDPOINT line-obj))
  (setq	pline-obj (VLA-ADDLIGHTWEIGHTPOLYLINE
		    model		;not know how to make vlax-make-safearray vlax-vbDouble  st-point en-point))
		  ) ;_ end of VLA-ADDLIGHTWEIGHTPOLYLINE
  ) ;_ end of setq
Thanks in advance
Do you have to go through VLA-xxx....
Here is simple approach :
(entmake
  (list
    (cons 0 "LWPOLYLINE")
    (cons 100 "AcDbEntity")
    (cons 100 "AcDbPolyline")
    (cons 90 2)
    (cons 70 (* 128 (getvar (quote plinegen))))
    (cons 38 0.0)
    (cons 10 st-point)
    (cons 10 en-point)
    (list 210 0.0 0.0 1.0)
Of course, this is only for lines that lie in WCS, otherwise I guess you'll have to go throught building OCS Z axis 210 group code, supply it at the end of (entmake)...
All in all things go messy when points are 3D as you'll have to use also (v^v) - cross product sub, (unit) sub function and still we don't know in what plane will lie LWPOLYLINE as you can put infinitely number of planes passing those 2 points that are in 3D...
There is also this - going through command "pedit"... I've just tested and it worked for both 2d and 3d lines...
(defun c:lines2lws ( / ss )
  (prompt "\nSelect LINE entities on unlocked layer(s)...")
  (if (setq ss (ssget "_:L" (list (cons 0 "LINE"))))
    (if command-s
      (command-s "_.pedit" "_m" ss "" "")
      (vl-cmdf "_.pedit" "_m" ss "" "")
Regards, M.R.
Quote
The conversion could be done like this in your code:
(vlax-safearray->list (vlax-variant-value st-point))
but it would be simpler to do like this:
(vlax-curve-getStartPoint line-ent)
This will avoid a conversion in one direction then the other...
  ) ;_ end of setq
Thanks @marko_ribar
I just wish to do it by VL , not ENTMAKE , or ACAD command line .  Just for learning.
Thanks @Tsuky I will try .
Maybe I did a wrong question .
As per Activex Reference guide
Quote
RetVal = object.AddLightWeightPolyline(VerticesList)
It ask for VERTICES LIST , as follow
Quote
object
Type: Block, ModelSpace, PaperSpace
The objects this method applies to.
VerticesList
Access: Input-only
Type: Variant (array of doubles)
The array of 2D OCS coordinates specifying the vertices of the polyline. At least two points (four elements) are required for constructing a lightweight polyline. The array size must be a multiple of 2.
 So my question is how to populate the VERTICES LIST , whit.
Don't worry about WCS or UCS .
Maybe this sub can help you...
(defun SafearrayVariant ( coords )
  (vlax-make-variant
    (vlax-safearray-fill
      (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length coords)))) coords
HTH.
M.R.
Here a snippet that does it.  Originally by PNorman i modified the variable name.
Note that the var *acspace must be defined.
ymg
(vl-load-com)
   (or *acdoc (setq *acdoc  (vla-get-ActiveDocument (vlax-get-acad-object))))
   (or *acutil (setq acutil  (vla-get-Utility *acdoc)))
   (setq *acspace (if (= (getvar "CVPORT") 1)
                     (vla-get-PaperSpace *acdoc)
                     (vla-get-ModelSpace *acdoc)
;; addlwp  by pnorman                                 ;
;; Add light weight polyline to model or paper space  ;
;; Global var *acspace must be defined                ;
;; Requires subroutine UCS2WCS                        ;
(defun addlwp (pl / sa)
  (setq pl (UCS2WCS pl))
  (setq pl (apply 'append pl))
  (setq	sa (vlax-make-safearray
	     vlax-vbDouble
	     (cons 0 (- (vl-list-length pl) 1))
  (vlax-safearray-fill sa pl)
  (vla-addLightweightPolyline *acspace sa)
;; convert list of 2D or 3D points from UCS to WCS    ;
(defun UCS2WCS (pl)
  (setq pl (mapcar '(lambda (p) (trans p 1 0)) pl))
  (setq
    pl (mapcar '(lambda (p) (list (float (car p)) (float (cadr p))))
	       pl
Edited by ymg3
To be more to the point with your question the point list is a list of list
(setq p1 (list 10.0 20.0 0))
(setq p2 (list 35.0 48.0 0.0))
(setq pointlist (list p1 p2))
;; so pointlist will be ((10.0 20.0 0) (35.0 48.0 0.0))
If you want to avoid variants, you can do like this. The code is minimalist.
(defun c:line2pline ( / AcDoc Space ss line-ent st-point en-point l_pt)
  (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space
    (if (eq (getvar "CVPORT") 1)
      (vla-get-PaperSpace AcDoc)
      (vla-get-ModelSpace AcDoc)
  (while (setq ss (ssget "_:S+." '((0 . "LINE"))))
    (setq
      line-ent (ssname ss 0)
      st-point (vlax-curve-getStartPoint line-ent)
      en-point (vlax-curve-getEndPoint line-ent)
      l_pt (apply 'append (mapcar '(lambda (x) (list (car x) (cadr x))) (list st-point en-point)))
    (vlax-invoke Space 'AddLightWeightPolyline l_pt)
    (entdel line-ent)
  (prin1)
  • Agree 1
This part :
Should just be :
[EDIT : Nevermind that, it looks that mapcar part is OK - you need just x and y coordinate, ommiting z one - apologise my mistake...]
Edited by marko_ribar
@Tsuky  I do not want to avoid VARIANT, why?
Perche mi piache .[ because I like it]
I want to make the lwpolyline  by variant , the same way I can make a new LINE, or a CIRCLE,  or a TEXT ,  with the variant .
Please see the code, I can make a new LINE, a CIRCLE and a TEXT at ST-point
Neither I can make a LWpolyline, or a Polyline, or a 3DPOLYLINE
I run at ACAD 2019
  (VL-LOAD-COM)
  (setq line-ent-ss (ssget "_x" '((0 . "line"))))
  (setq line-obj-ss (VLA-GET-ACTIVESELECTIONSET adoc))
(Setq line-obj (vla-item line-obj-ss 0))
(setq st-circle (VLA-ADDCIRCLE model st-point 10))
;;#<VLA-OBJECT IAcadCircle 000002499a1446c8>
(setq line-st-en (VLA-ADDLINE model  st-point en-point))
;;;#<VLA-OBJECT IAcadLine 000002499a144c68>
(setq st-text (VLA-ADDTEXT model  "start-point" st-point (getvar 'TEXTSIZE)))
;#<VLA-OBJECT IAcadText 00000249ac0e1f58>
			  model	(list st-point en-point)
	) ;_ end of setq
; error: lisp value has no coercion to VARIANT with this type:  (#<variant 8197 ...> #<variant 8197 ...>)
(setq pline-obj-01	(VLA-ADDLIGHTWEIGHTPOLYLINE
	) ;_ end of setq
  ; error: Too many actual parameters
(setq pline-obj-02	(VLA-ADDPOLYLINE
			) ;_ end of VLA-POLYLINE
	) ;_ end of setq
  ) ;_ end of defun
@devitg The argument for a polyline has to be a single array structure with the coordinates as elements; it is not the same as a list.
Use this function to convert a standard list of points into something that can be used in the vla-addlwpolyline function:
  Function Name: (pjk-PointList->SafeArray)
  Arguments: plist = list; a list of points
  Usage Example: (pjk-PointList->SafeArray '((0.0 0.0 0.0)(1.0 1.0 0.0)))
  Returns: a VLA SafeArray type
  Description:
     This Function converts a list of Points into a SafeArray
     to plug into a Visual LISP ActiveX property.
(defun pjk-PointList->SafeArray (plist / fl)
   (setq fl (apply 'append plist))
   (vlax-make-variant
         (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length doubles))))
         fl
) ;; End Function (pjk-PointList->SafeArray)
Here, @devitg
your example mod. to suit your needs...
(defun lines-as-ents-by-vl ( / safearrayvariant acad-obj adoc model line-ent-ss line-obj-ss line-obj st-point en-point st-circle line-st-en st-text pline-obj-1 pline-obj-2 lst )
  (vl-load-com)
  (defun safearrayvariant ( coords )
    (vlax-make-variant
  (setq acad-obj (vlax-get-acad-object)) ;_ el programa ACAD
  (setq adoc (vla-get-activedocument acad-obj)) ;_ el DWG que esta abierto-
  (setq model (vla-get-modelspace adoc))
  (setq line-ent-ss (ssget "_x" (list (cons 0 "line"))))
  (setq line-obj-ss (vla-get-activeselectionset adoc))
  (setq line-obj (vla-item line-obj-ss 0))
  (setq st-point (vla-get-startpoint line-obj))
  (setq en-point (vla-get-endpoint line-obj))
  (setq st-circle (vla-addcircle model st-point 10))
  (setq lst (cons st-circle lst))
  (setq line-st-en (vla-addline model st-point en-point))
  (setq lst (cons line-st-en lst))
  (if (= (getvar (quote textsize)) 0.0)
    (setvar (quote textsize) 2.5)
  (setq st-text (vla-addtext model "start-point" st-point (getvar (quote textsize))))
  (setq lst (cons st-text lst))
  (setq pline-obj-1 (vla-addlightweightpolyline model (safearrayvariant (apply (function append) (mapcar (function (lambda ( x ) (list (car x) (cadr x)))) (list (safearray-value (variant-value st-point)) (safearray-value (variant-value en-point))))))))
  (setq lst (cons pline-obj-1 lst))
  (setq pline-obj-2 (vla-addpolyline model (safearrayvariant (apply (function append) (list (safearray-value (variant-value st-point)) (safearray-value (variant-value en-point)))))))
  (setq lst (cons pline-obj-2 lst))
  lst
: (lines-as-ents-by-vl)
(#<VLA-OBJECT IAcadPolyline 000000004C23B8F0> #<VLA-OBJECT IAcadLWPolyline 000000004C23B970> #<VLA-OBJECT IAcadText 000000004C23B2F0> #<VLA-OBJECT IAcadLine 000000004C23B070> #<VLA-OBJECT IAcadCircle 000000004C23B670>)
HTH.
M.R.
I think it has been well explained, but just to say this, here you are trying to make a polyline with just two points, think about the case where you have more points (which is usually the case with polylines), so the argument has to be a variant (array of doubles)
Edited by lastknownuser
  • Agree 1
I run at ACAD 2019
  (VL-LOAD-COM)
	) ;_ end of setq
	) ;_ end of setq
	) ;_ end of setq
  ) ;_ end of defun
45 minutes ago, marko_ribar said:
@marko_ribar  Just as a personal and own chose or will and wish    I do not want to use COORDS ,            I want to use what the  activex reference guide state
 Just a kid's whim.
Quote
AddLightWeightPolyline Method (ActiveX)
object
VerticesList
Access: Input-only
Of course I can use a  previous defun to AddLightWeightPolyline , form point list
  (DEFUN DT:LIST-FLATTEN  (LISTE /)
    (COND
      ((NULL LISTE) NIL)
      ((ATOM LISTE) (LIST LISTE))
      (1
       (APPEND (DT:LIST-FLATTEN (CAR LISTE))
               (DT:LIST-FLATTEN (CDR LISTE))))
    ) ;_ DT:LIST-FLATTEN
;;;(setq lst[['(915.33 476.258 913.419 573.61 844.641 623.24 817.894 564.066 915.33 476.258) )
  ;;sola lista (list x1 y1 z 1 x2 y2 z2 .....xn yn zn)
  (DEFUN I:POINTS  (PTLIST)
    (VL-LOAD-COM)
    (VLAX-SAFEARRAY-FILL
      (VLAX-MAKE-SAFEARRAY
        VLAX-VBDOUBLE
        (CONS 0 (1- (LENGTH PTLIST)))
      PTLIST
    ) ;_end defun i:Points
(DEFUN LIST->2DPOLY  (LISTA)
  (SETQ FLAT-LIST (DT:LIST-FLATTEN LISTA))
  (SETQ SAF (I:POINTS FLAT-LIST))
  (VLA-ADDLIGHTWEIGHTPOLYLINE MODEL SAF)
DT:LIST-FLATTEN and I:POINT , are not mine .
Thanks all you for your help.
Hope I can get the way to use the points as VARIANTS , and not as ( LIST  x y z )
 Just a kid's whim.
And it states one argument, variant (array of doubles). Double is a number. Coordinates are defined by a number. So you have to "use" coordinates. From my understanding, and I'm not an expert I have only recently started digging deeper into Active X stuff, your st-point and en-point are variants right. So "vlax-make-safearray vlax-vbDouble st-point en-point" doesn't work, can't work. And afaik you can't make a variant (array of doubles) with variants st-point and en-point without getting their coordinates (that are - double), what you are here for some reason trying to avoid.
To give a comparison with AutoLISP, its like wanting to create a line by only selecting two points with (car (entsel)). You get entity of each point, but you have to extract its coordinates to eventually create a line.
If I'm wrong someone correct me of course.
  • Agree 1
@lastknownuser I'm wrong. I will do the poly by point coordinates. Thanks.
