Hi!
First of all, I dont want to use LAYISO here. That is cause I need to set the settings to turn off layers ... some users may have it set to lock maybe.
Anyways...
Here is my lisp that picks entities and when they are picked all but picked turns off.
When I pick them I dont see on the screen that they are marked as picked. Only in command line I see what object are picked.
How can I modify it to show me picked entities as picked.
(defun c:off_layEXC ()
 (setvar "cmdecho" 0)
 (setq ent nil
lista nil
typ_ent nil
lager nil
typ_lager nil
namn nil
nr_lista nil
namn_lista
 nil
 (setq ent T)
 (setvar "clayer" "0")
 (while (/= ent nil)
   (setq ent (car (entsel "\nChoose object: ")))
   (if ent
(setq typ_lager (cdr (assoc 8 (entget ent))))
(prompt (strcat " Layer " typ_lager " chosen"))
(setq lista (append lista (list typ_lager)))
     (setq ent nil)
 (setvar "clayer" (nth 0 lista))
 (command "_layer" "off" "*" "n" "")
 (setq nr 1)
 (while (< nr (length lista))
   (command "_layer" "on" (nth nr lista) "")
   (setq nr (1+ nr))
I'm not sure about I understanf your goal
Try this edited version, you can see the way how to
select entities with grips, another piece of code
you could be edit by youself :)
(defun c:off_layEXC (/ en ent lista nr typ_lager ss)
 (setq ss (ssadd))
 (setq ent T)
 (setvar "clayer" "0");--> do you need restore this setting after?
 (while (/= ent nil)
   (setq ent (entsel "\nChoose object: "))
   (if ent
(setq en (car ent))
(setq typ_lager (cdr (assoc 8 (entget en))))
 (ssadd en ss)
(sssetfirst nil ss)
(if (not (member typ_lager lista)); to avoid to put duplicate layer name into layer name list
(setq lista (append lista (list typ_lager))))
(setq ent nil)
 (alert "Rest code block goes here")
 (setq nr 1)
   (setq nr (1+ nr))
 (setvar "cmdecho" 1)
~'J'~
Or maybe something like this? -David
[b][color=BLACK]([/color][/b]defun c:offelay [b][color=FUCHSIA]([/color][/b]/ ss i ll en ln ls[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setvar [color=#2f4f4f]"HIGHLIGHT"[/color] 1[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not ss[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\Select Entities To Show..."[/color][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=RED])[/color][/b]
                                  [b][color=RED]([/color][/b]cons 410 [b][color=PURPLE]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
                                  [b][color=RED]([/color][/b]cons 67 [b][color=PURPLE]([/color][/b]- 1 [b][color=TEAL]([/color][/b]getvar [color=#2f4f4f]"TILEMODE"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq i [b][color=NAVY]([/color][/b]sslength ss[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq ll [b][color=NAVY]([/color][/b]list [b][color=MAROON]([/color][/b]getvar [color=#2f4f4f]"CLAYER"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]minusp [b][color=GREEN]([/color][/b]setq i [b][color=BLUE]([/color][/b]1- i[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq en [b][color=MAROON]([/color][/b]ssname ss i[b][color=MAROON])[/color][/b]
              ln [b][color=MAROON]([/color][/b]cdr [b][color=GREEN]([/color][/b]assoc 8 [b][color=BLUE]([/color][/b]entget en[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]member ln ll[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b]setq ll [b][color=GREEN]([/color][/b]cons ln ll[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq ls [color=#2f4f4f]""[/color][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]foreach l ll [b][color=NAVY]([/color][/b]setq ls [b][color=MAROON]([/color][/b]strcat ls l [color=#2f4f4f]","[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.LAYER"[/color] [color=#2f4f4f]"_OFF"[/color] [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]"~"[/color] [b][color=MAROON]([/color][/b]getvar [color=#2f4f4f]"CLAYER"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [color=#2f4f4f]"_ON"[/color] ls [color=#2f4f4f]""[/color][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
