choupi1968 Posted March 14, 2024 Posted March 14, 2024 hello how to connect with a line or a polyline several blocks of different names with the same ADDRESS attribute names In order 001 002 003 etc… THANKS Quote
mhupp Posted March 14, 2024 Posted March 14, 2024 Sounds easy enough just need to make a selection set of the blocks step thought the selection set pulling the entity name and attribute value into a list. sort the list by the the attribute. then process the list and pull the block base point. Quote
fuccaro Posted March 15, 2024 Posted March 15, 2024 @mhupp Do you mean something like this? (defun c:pp( / ssb) (setq ssb (ssget "X" '((0 . "INSERT")(66 . 1))) lst nil) (repeat (setq i (sslength ssb)) (setq b1 (ssname ssb (setq i (1- i))) poz (cdr (assoc 10 (entget b1)))) (while (and (/= (cdr (assoc 0 (setq attl (entget (setq b1 (entnext b1)))))) "SEQUEND") (/= (cdr (assoc 2 attl)) "ADDRESS"))) (setq lst (cons (cons poz (cdr (assoc 1 attl))) lst)) ) (setq lst (vl-sort lst '(lambda (x y) (< (cdr x) (cdr y)))) lst (mapcar '(lambda (x) (cons 10 (car x))) lst)) (foreach x (list (cons 90 (length lst)) '(100 . "AcDbPolyline") '(100 . "AcDbEntity") '(0 . "LWPOLYLINE")) (setq lst (cons x lst))) (entmake lst) ) Quote
choupi1968 Posted March 16, 2024 Author Posted March 16, 2024 hello I expressed myself badly in my last post. the pp lisp works really well, but I'm looking for it to also work if the "ADDRESS" attribute is indicated like this L1-001, L1-002, L1-003,...etc or B01-001,B01-002, B01-003...etc or 1/1/1-001, 1/1/1-002, 1/1/1-003 etc... with the lisp line (list (cdr (assoc 1 (entget att))) (cdr (assoc 10 (entget blk)))) by tracing Arc polylines with (command "_.pline" break "_arc") If anyone has any ideas THANKS Quote
mhupp Posted March 16, 2024 Posted March 16, 2024 4 hours ago, choupi1968 said: hello I expressed myself badly in my last post. Yes, it was one sentence. posting a sample drawing is usually best Quote
choupi1968 Posted March 17, 2024 Author Posted March 17, 2024 Quote Hello, you are right with an autocad file it will be clearer, to explain what I want. Happy Sunday and thank you for your help. Sincerely Philip TEST CABLAGE-001.dwg Quote
fuccaro Posted March 18, 2024 Posted March 18, 2024 I am a bit confused now. The program I wrote should sort those attributes, whatever they contains. 1 Quote
Tsuky Posted March 19, 2024 Posted March 19, 2024 @choupi1968 @fuccaro 's code works fine. With your exemple, you must just remove "X" at (ssget) and change the tag "ADDRESS" to "ORDRE"" 1 1 Quote
fuccaro Posted March 19, 2024 Posted March 19, 2024 Here is the program changed... almost as you requested. (defun c:pp( / ssb) (setq ssb (ssget '((0 . "INSERT")(66 . 1))) lst nil bulge 0.2) (repeat (setq i (sslength ssb)) (setq b1 (ssname ssb (setq i (1- i))) poz (cdr (assoc 10 (entget b1)))) (while (and (/= (cdr (assoc 0 (setq attl (entget (setq b1 (entnext b1)))))) "SEQUEND") (/= (cdr (assoc 2 attl)) "ORDRE"))) (setq lst (cons (cons poz (cdr (assoc 1 attl))) lst)) ) (setq lst (vl-sort lst '(lambda (x y) (< (cdr x) (cdr y)))) lst (mapcar '(lambda (x) (cons 10 (car x))) lst)) (setq l1 (list '(0 . "LWPOLYLINE")'(100 . "AcDbEntity")'(100 . "AcDbPolyline")(cons 90 (length lst)))) (foreach x lst (setq l1 (append l1 (list x))) (setq l1 (append l1 (list (cons 42 (setq bulge (- bulge)))))) ) (entmake l1) ) It will draw a curved polyline. Select it, than drag the ARC's midpoint to the desired position Quote
choupi1968 Posted March 19, 2024 Author Posted March 19, 2024 (edited) hello it's great I was just looking for a solution with the following lisp. thank you very much, have a good evening. Philippe. (defun c:pl2arc ( / massoclst nthmassocsubst v^v unit _ilp doc lw enx gr enxb p1 p2 p3 b i n ) (vl-load-com) (defun massoclst ( key lst ) (if (assoc key lst) (cons (assoc key lst) (massoclst key (cdr (member (assoc key lst) lst))))) ) (defun nthmassocsubst ( n key value lst / k slst p j plst m tst pslst ) (setq k (length (setq slst (member (assoc key lst) lst)))) (setq p (- (length lst) k)) (setq j -1) (repeat p (setq plst (cons (nth (setq j (1+ j)) lst) plst)) ) (setq plst (reverse plst)) (setq j -1) (setq m -1) (repeat k (setq j (1+ j)) (if (equal (assoc key (member (nth j slst) slst)) (nth j slst) 1e-6) (setq m (1+ m)) ) (if (and (not tst) (= n m)) (setq pslst (cons (cons key value) pslst) tst t) (setq pslst (cons (nth j slst) pslst)) ) ) (setq pslst (reverse pslst)) (append plst pslst) ) (defun v^v ( u v ) (mapcar '(lambda ( s1 s2 a b ) (+ ((eval s1) (* (nth a u) (nth b v))) ((eval s2) (* (nth a v) (nth b u))))) '(+ - +) '(- + -) '(1 0 0) '(2 2 1)) ) (defun unit ( v ) (mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v) ) (defun _ilp ( p1 p2 o nor / p1p p2p op tp pp p ) (if (not (equal (v^v nor (unit (mapcar '- p2 p1))) '(0.0 0.0 0.0) 1e-7)) (progn (setq p1p (trans p1 0 (v^v nor (unit (mapcar '- p2 p1)))) p2p (trans p2 0 (v^v nor (unit (mapcar '- p2 p1)))) op (trans o 0 (v^v nor (unit (mapcar '- p2 p1)))) op (list (car op) (cadr op) (caddr p1p)) tp (polar op (+ (* 0.5 pi) (angle '(0.0 0.0 0.0) (trans nor 0 (v^v nor (unit (mapcar '- p2 p1)))))) 1.0) ) (if (inters p1p p2p op tp nil) (progn (setq p (trans (inters p1p p2p op tp nil) (v^v nor (unit (mapcar '- p2 p1))) 0)) p ) nil ) ) (progn (setq pp (list (car (trans p1 0 nor)) (cadr (trans p1 0 nor)) (caddr (trans o 0 nor)))) (setq p (trans pp nor 0)) p ) ) ) (or doc (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))) (vla-startundomark doc) (if (and (setq lw (entsel "\nPick LWPOLYLINE...")) (= (cdr (assoc 0 (setq enx (entget (car lw))))) "LWPOLYLINE") ) (progn (setq i (fix (vlax-curve-getParamAtPoint (car lw) (vlax-curve-getClosestPointToProjection (car lw) (trans (cadr lw) 1 0) '(0.0 0.0 1.0)) ) ;_ vlax-curve-getParamAtPoint ) ;_ fix p1 (vlax-curve-getPointAtParam (car lw) i) p3 (vlax-curve-getPointAtParam (car lw) (1+ i)) lw (car lw) ) (setq enxb (massoclst 42 enx)) (while (= 5 (car (setq gr (grread t)))) (setq p2 (_ilp (trans (cadr gr) 1 0) (mapcar '+ (trans (cadr gr) 1 0) '(0.0 0.0 1.0)) p1 (cdr (assoc 210 (entget lw))))) (setq b ((lambda (a) (/ (sin a) (cos a))) (/ (- (angle (trans p2 0 lw) (trans p3 0 lw)) (angle (trans p1 0 lw) (trans p2 0 lw))) 2.0) ) ) (setq n -1) (foreach dxf42 enxb (setq n (1+ n)) (if (= n i) (setq enx (nthmassocsubst n 42 b enx)) (setq enx (nthmassocsubst n 42 (+ (cdr dxf42) b) enx)) ) ) (entupd (cdr (assoc -1 (entmod enx)))) ) ) (prompt "\n Nothing selected or picked object not a LWPOLYLINE ") ) (vla-endundomark doc) (princ) ) Edited March 20, 2024 by fuccaro Adding <> Quote
fuccaro Posted March 20, 2024 Posted March 20, 2024 In the future, please use CODE tags to post ... well... code. I just added a bulge factor of +/- 0.2, I think is better than the Command... arc... as you suggested. I see the curved polyline in the drawing you uploaded. How do you decide what radius to use for each polyline segment? Is there a formula that could be implemented in the Lisp program? Quote
choupi1968 Posted April 6, 2024 Author Posted April 6, 2024 Hello, sorry for the late response, I got sick. thanks for the lisp PP. it is perfect and in my daily life it does not need to be improved... for the moment. Post a Code I'll be careful next time. THANKS I have another challenge to offer you: distribute X number of blocks in an irregular polygon. Regardless of the scale, size or surface area of the polygon. Kind regards Philip Quote
XDSoft Posted April 8, 2024 Posted April 8, 2024 (edited) On 3/15/2024 at 2:37 AM, choupi1968 said: hello how to connect with a line or a polyline several blocks of different names with the same ADDRESS attribute names In order 001 002 003 etc… THANKS Batch processing https://www.theswamp.org/index.php?topic=59427.0 Edited April 9, 2024 by XDSoft Quote
XDSoft Posted April 9, 2024 Posted April 9, 2024 (edited) [XDrX-PlugIn(126)] Connecter attrib blocks by tag (theswamp.org) https://www.theswamp.org/index.php?topic=59427.0 (defun c:xdtb_att-connect (/ att bulge delim ents i lst nums pl pts ss str str1 strl strl1 tag x y) (defun _get-data () (and (setq att (car (xdrx-nentselex (xdrx-string-multilanguage "\n拾取要排序的属性标签字符串<退出>:" "\nPick the attribute label string to be sorted<Exit>:") '((0 . "att*")) ) ) ) (setq tag (xdrx-getpropertyvalue att "tag")) (/= "" (setq delim (getstring (xdrx-string-multilanguage "\n属性分割符<退出>:" "\nAttribute separator <exit>:" ) ) ) ) (setq ss (xdrx-ssget (xdrx-string-multilanguage "\n选择属性块<退出>:" "\nSelect attribute block <Exit>:" ) '((0 . "insert") (66 . 1)) ) ) ) ) (defun _analyze-data () (setq lst nil) (mapcar '(lambda (x) (setq ents (xdrx-getpropertyvalue x "AttributeEntities")) (if (vl-some '(lambda (y) (if (= tag (xdrx-getpropertyvalue y "tag")) (setq str (xdrx-getpropertyvalue y "textstring")) ) ) ents ) (progn (if (setq str1 (xdrx-string-split str delim)) (setq lst (cons (list (car str1) str x) lst)) ) ) ) ) (xdrx-ss->ents ss) ) (setq lst (xd::list:groupbyindex lst 0.1)) (setq lst (mapcar '(lambda (x) (setq strl (cdr x)) (setq strl1 (mapcar 'car strl ) strl1 (xdrx-string-sort strl1) ) (mapcar '(lambda (y) (assoc y strl) ) strl1 ) ) lst ) ) ) (defun _connect-line () (setq bulge 0.155) (mapcar '(lambda (x) (setq ents (mapcar 'cadr x ) ) (setq pts (xdrx-getpropertyvalue ents "position") pts (apply 'append pts ) ) (setq pl (xdrx-polyline-make pts)) (setq nums (xdrx-getpropertyvalue pl "numverts")) (setq i 0) (repeat nums (if (= (rem i 2) 1) (setq bulge (- bulge)) ) (xdrx-setpropertyvalue pl "bulgeat" (list i bulge)) (setq i (1+ i)) ) ) lst ) ) (if (_get-data) (progn (xdrx-begin) (_analyze-data) (_connect-line) (xdrx-end) ) ) (princ) ) Edited April 9, 2024 by XDSoft Quote
