why does the level change when you move a 3d model in autocad
Explain more what it is your doing when moving.
im moving a 3D drawing from from grid to the other( eg moving from national grid to a local grid). the level should remain the same but in this case the level changes,  i dont know why )
Having a hard time understanding why you're moving a Civil 3D drawing, are you trying to convert a drawing from one coordinate system to another?
It may be simpler to start a new drawing with the coordinate system you want and insert the other drawing.
I've only used Civil 3D with one Map 3D projection zone and have never had a need to move a drawing.
When you say the level changes are you talking about the elevations?
Map 3D moving from national grid to a local grid
  • 2 weeks later...
Hi Benard,
"I'm moving a 3D drawing from from grid to the other(eg moving from national grid to a local grid)."
More details please. Can you attach or post a link to your drawing?
Dave
Forgot about just use UCS for the local grid but save the UCS can then swap between local and World.
Looks like Benard has gone home.
