Tsuky Posted March 22, 2024 Posted March 22, 2024 On 3/22/2024 at 4:07 PM, Nikon said: I am changing (cons 1 (rtos 0.0 2 3)), I add it at the beginning of the code: (setq oldsnap (getvar 'dimzin)) (setvar 'dimzin 0) and at the end of the code (setvar "dimzin" oldsnap) block 0 is displayed as 0.000 Maybe I don't understand something... Can add a mirror request to the code? Or is it difficult? Expand This is a little more complicated because I don't know how to make a dynamic block in lisp. But manually it is possible. Steps: Click on a LEVEL-OBJ block with the right-click enter the block editor Select the attribute and in the properties change LOCK POSITION to 'on' Same for multiline Choose the Flip setting by setting a vertical axis from the tip of the arrow. Then in Actions choose the flip action and select your parameter then all the objects (attribute included) Exit the editor saving the changes In the drawing do an ATTSYNC then a REGENALL If done correctly you will be able to reverse your block with the little arrow NB: DIMZIN at 0 is very good for keeping zeros at the beginning and end (oldsnap is not a good choice: OSNAP is another variable, but if you declare it in local variable, is not important) 1 Quote
Nikon Posted March 22, 2024 Posted March 22, 2024 On 3/22/2024 at 7:03 PM, Tsuky said: But manually it is possible. Expand Thanks, I'll try.... Quote
