Hello, I'm trying to write a code that changes the dimension style of all dimensions in layer Dimension(ISO). I need the code to change it to variable "DimStyleOverrider" and this variable must be dependant on another variable. When OldFactor = 10 I need "DimStyleOverrider" to be "Change10" and when OldFactor = 5 I need it to be "Change5". You can assume these styles already exist in the file. I hope someone can help me.
Edited by ElAmigo
  On 3/8/2024 at 12:17 PM, ElAmigo said:
I have been able to solve it :)
Expand
@ElAmigo it would be nice if you could share your solution, so we can learn about it.
(defun WhichDimension ()
  (setq DimStyleOverrider
    (cond
      ((= OldFactor 5) "Change5")
      ((= OldFactor 10) "Change10")
(defun example ()
	(WhichDimension)
	(while (< i (sslength selectie))
   	 (setq ent (ssname selectie i)) ;
   	 (setq data (entget ent))
   	 (if (= (cdr (assoc 0 data)) "DIMENSION") ;
        (setq newData (subst (cons 3 DimStyleOverrider) (assoc 3 data) data)) ; Changes DIMSTYLE
        (entmod newData)
        (entupd ent)
    (setq i (+ i 1))
I hope this is clear enough. Had to change some names. This code works for me but after changing the DIMSTYLE it doesn't update everything that should. I created another post about that because I haven't been able to find a solution in days.
    (cond
(defun example ()
	(WhichDimension)
        (entmod newData)
        (entupd ent)
    (setq i (+ i 1))
Expand
@ElAmigo Thanks
