automicro Posted March 4, 2009 Posted March 4, 2009 Hallo I am a new user on Autocad and this fortum. Have run Microstation before and this is very new for me. I got a problem. I have more then >100 dwg files there i need too increase postions z value of text and even change text too the new value of z Text are on 3 diffrents levels/layers. Example of old text and z value Text contents = "Z90.00" or "Z 90.00" Text alignment = 90.0000 Text position z = 90.0000 Result will be ( increase .28) Text contents = "Z90.28" or "Z 90.28" Text alignment = 90.28 Text position z = 90.28 Is it possible too do on a easy way? /Beginner Quote
Lee Mac Posted March 4, 2009 Posted March 4, 2009 Firstly, welcome to the forums, hope you like it here and find what you need Yes, I think this could be accomplished using LISP - I do have a few minor questions however: Is it a 0.28 increase for all text on the three layers? Could you provide the exact names of the layers on which the text resides? Quote
automicro Posted March 4, 2009 Author Posted March 4, 2009 Firstly, welcome to the forums, hope you like it here and find what you need Yes, I think this could be accomplished using LISP - I do have a few minor questions however: Is it a 0.28 increase for all text on the three layers? Could you provide the exact names of the layers on which the text resides? Thanks Lee Mac. Yes all text on this three layers (LEVEL, LEVEL-KYL, LEVEL-S) Discovered that I must use the value in the text and this value is to be increase by 0.28. That text be changed to the new value after that are calculated. And the text position z value will be the same as text. /automicro Quote
Lee Mac Posted March 4, 2009 Posted March 4, 2009 Try this: [b][color=BLACK]([/color][/b]defun c:txtupd [b][color=FUCHSIA]([/color][/b]/ ss eLst tpt ntpt zval lst[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"*TEXT"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 8 [color=#2f4f4f]"LEVEL,LEVEL-KYL,LEVEL-S"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 410 [b][color=PURPLE]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 67 [b][color=PURPLE]([/color][/b]- 1 [b][color=TEAL]([/color][/b]getvar [color=#2f4f4f]"TILEMODE"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]progn [b][color=MAROON]([/color][/b]setq eLst [b][color=GREEN]([/color][/b]mapcar 'entget [b][color=BLUE]([/color][/b]mapcar 'cadr [b][color=RED]([/color][/b]ssnamex ss[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]foreach ent eLst [b][color=GREEN]([/color][/b]setq tpt [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 10 ent[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] ntpt [b][color=BLUE]([/color][/b]+ [b][color=RED]([/color][/b]last tpt[b][color=RED])[/color][/b] 0.28[b][color=BLUE])[/color][/b] zval [b][color=BLUE]([/color][/b]subst ntpt [b][color=RED]([/color][/b]last tpt[b][color=RED])[/color][/b] tpt[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]mapcar '[b][color=BLUE]([/color][/b]lambda [b][color=RED]([/color][/b]new old[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]setq lst [b][color=PURPLE]([/color][/b]subst new old ent[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]cons 10 zval[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 1 [b][color=PURPLE]([/color][/b]strcat [color=#2f4f4f]"Z"[/color] [b][color=TEAL]([/color][/b]rtos ntpt[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]assoc 10 ent[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]assoc 1 ent[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]entmod lst[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\n<!> No Text Found <!>"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]princ[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] Quote
automicro Posted March 5, 2009 Author Posted March 5, 2009 You are my hero Lee Mac, its works very fine. But when i show my boss, he say Rule 1: All texts will increase the z-text with 0.28. Rule 2: If text Z position> 0, z positions increase by 0.28 Is it possible to change the scrip to do so? /automicro Quote
eldon Posted March 5, 2009 Posted March 5, 2009 If you can select only text, then you could use the MOVE command @0,0,0.28 This would move all text by 0.28 in the z coordinate. Quote
Lee Mac Posted March 5, 2009 Posted March 5, 2009 If you can select only text, then you could use the MOVE command @0,0,0.28This would move all text by 0.28 in the z coordinate. True Eldon, but then I suppose he would still have to update the content of all the text to include the z-coord. *LISPing is much more fun* Thanks for the suggestion though Quote
Lee Mac Posted March 5, 2009 Posted March 5, 2009 You are my hero Lee Mac, its works very fine.But when i show my boss, he say Rule 1: All texts will increase the z-text with 0.28. Rule 2: If text Z position> 0, z positions increase by 0.28 Is it possible to change the scrip to do so? /automicro I'm sorry, I'm not sure that I completely understand you, Are you saying that only text with z-coord greater than zero needs to be moved and have its content updated? It seems "rule 1" and "rule 2" contradict each other - could you please clarify for me Quote
eldon Posted March 5, 2009 Posted March 5, 2009 I would have had to use a two stage process using the lisp TEXTMATH to alter the text of the levels, and then used MOVE to physically move everything in the z direction. All the tools are in existence, and you are just providing a Rolls-Royce service. Keep up the good work Quote
automicro Posted March 5, 2009 Author Posted March 5, 2009 I'm sorry, I'm not sure that I completely understand you, Are you saying that only text with z-coord greater than zero needs to be moved and have its content updated? It seems "rule 1" and "rule 2" contradict each other - could you please clarify for me Sorry about my bad english or bad declaration 1: All text on layer Level, level-kyl, level-s Needs too increase text value widht 0.28 Example "Z 90.00" will be "z 90.28" 2: Next step is too increase z coordinate (+0.28) on all text coordinates there the Z coordinate are greater then 0 3: Text coordinates widht Z value 0 shall not change. I hop you understand now. /automicro Quote
Lee Mac Posted March 5, 2009 Posted March 5, 2009 Give this a shot [b][color=BLACK]([/color][/b]defun c:txtupd [b][color=FUCHSIA]([/color][/b]/ ss eLst tpt tval npt lst[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]vl-load-com[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"*TEXT"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 8 [color=#2f4f4f]"LEVEL,LEVEL-KYL,LEVEL-S"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 410 [b][color=PURPLE]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 67 [b][color=PURPLE]([/color][/b]- 1 [b][color=TEAL]([/color][/b]getvar [color=#2f4f4f]"TILEMODE"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]progn [b][color=MAROON]([/color][/b]setq eLst [b][color=GREEN]([/color][/b]mapcar 'entget [b][color=BLUE]([/color][/b]mapcar 'cadr [b][color=RED]([/color][/b]ssnamex ss[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]foreach ent eLst [b][color=GREEN]([/color][/b]setq tpt [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 10 ent[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] tval [b][color=BLUE]([/color][/b]rtos [b][color=RED]([/color][/b]+ [b][color=PURPLE]([/color][/b]last tpt[b][color=PURPLE])[/color][/b] 0.28[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]if [b][color=BLUE]([/color][/b]> [b][color=RED]([/color][/b]last tpt[b][color=RED])[/color][/b] 0[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]setq npt [b][color=RED]([/color][/b]subst [b][color=PURPLE]([/color][/b]+ [b][color=TEAL]([/color][/b]last tpt[b][color=TEAL])[/color][/b] 0.28[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]last tpt[b][color=PURPLE])[/color][/b] tpt[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]setq npt tpt[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]mapcar '[b][color=BLUE]([/color][/b]lambda [b][color=RED]([/color][/b]new old[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]setq lst [b][color=PURPLE]([/color][/b]subst new old ent[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]cons 10 npt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 1 [b][color=PURPLE]([/color][/b]strcat [color=#2f4f4f]"Z"[/color] tval[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]assoc 10 ent[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]assoc 1 ent[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]entmod lst[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\n<!> No Text Found <!>"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]princ[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] Quote
automicro Posted March 6, 2009 Author Posted March 6, 2009 Give this a shot Not that i mean, perhaps this explain better FOR ELEMENT=0 TO ALL.ELEMENT ::rem ALL ELEMENT IN FILE IF Layer = "LEVEL" or Layer = "LEVEL-KYL" or Layer = "LEVEL-S" THEN IF Txt.txt = "Z xx.xx" or Txt.txt = "Zxx.xx" THEN Txt.txt = Txt.txt + ".28" ::rem example Txt.txt = "Z 90.00" ==> Txt.txt = "Z 90.28" ::rem example Txt.txt = "Z90.00" ==> Txt.txt = "Z90.28" IF Txt.Z.COORD > 0 THEN Txt.Z.COORD = TEXT.Z.COORD + 0.28 ::rem example ONLY when Txt.Z.COORD >0 else Txt.Z.COORD = 0 ENDIF ENDIF NEXT ELEMENT Can some one show me, how i can read hole dwgfile in a "FOR" loop in VB and check all elementyp and change element values? Are very bad on lisp. ´ /automicro Quote
Lee Mac Posted March 6, 2009 Posted March 6, 2009 Does the above not accomplish what you are asking for? Quote
automicro Posted March 9, 2009 Author Posted March 9, 2009 Your lisp program don't increase text value My text z88.52 ==> Z0.2800 with your program but i expect Z88.80 Your program does not increase the value of the Z-text without replacing it to 0.28 /automicro Quote
Lee Mac Posted March 9, 2009 Posted March 9, 2009 Hmm, that is weird, that doesn't happen when I run it (see attached.) TxtUpd.zip Quote
automicro Posted March 10, 2009 Author Posted March 10, 2009 Hmm, that is weird, that doesn't happen when I run it (see attached.) I think you pick the z value from the "z coordinate" of text and not from the "text value" Many texts are on z coordinate 0 but shall not change. Thanks for all help Lee Mac /automicro Quote
Lee Mac Posted March 10, 2009 Posted March 10, 2009 Ok, try this - sorry for confusion earlier: (defun c:txtupd (/ ss eLst tpt tval npt lst) (vl-load-com) (if (setq ss (ssget "X" (list (cons 0 "*TEXT") (cons 8 "0") (if (getvar "CTAB") (cons 410 (getvar "CTAB")) (cons 67 (- 1 (getvar "TILEMODE"))))))) (progn (setq eLst (mapcar 'entget (mapcar 'cadr (ssnamex ss)))) (foreach ent eLst (setq tpt (cdr (assoc 10 ent))) (if (eq (nth 1 (vl-string->list (cdr (assoc 1 ent)))) 32) (setq tval (rtos (+ (distof (substr (cdr (assoc 1 ent)) 3)) 0.28))) (setq tval (rtos (+ (distof (substr (cdr (assoc 1 ent)) 2)) 0.28)))) (if (> (last tpt) 0) (setq npt (subst (+ (last tpt) 0.28) (last tpt) tpt)) (setq npt tpt)) (mapcar '(lambda (new old) (setq lst (subst new old ent))) (list (cons 10 npt) (cons 1 (strcat "Z" tval))) (list (assoc 10 ent) (assoc 1 ent))) (entmod lst))) (princ "\n<!> No Text Found <!>")) (princ)) Quote
automicro Posted March 10, 2009 Author Posted March 10, 2009 When i run this i get a error message. Command: _appload txtupd-2009-03-10.lsp successfully loaded. Command: txtupd ; error: bad argument type: numberp: nil Quote
