Hello freinds
how can i draw spline from a list
say i have a list
(setq mylist(append list1 list2))
(command "_spline")
(foreach pt mylist
(comand pt)
(command "")
(command"")
(command"")
i saw this way from working lisp
but here not working any help will be appreciated
thanks
Hello freinds
say i have a list
(command "_spline")
(foreach pt mylist
(command pt)
(command "")
(command"")
(command"")
thanks
Could this be your problem?
this is my lisp to draw spline and asking for z value
i got the list of points i picked but spline not drawen
(defun c:3dsp (/)
(setq allpt '())
(while
(setq a (getpoint "\n Pick Point: "))
(setq osmd(getvar"osmode"))
(initget 1)
(setq pt11 (entget (car (entsel "\nSelect Text level: "))))
(setq txtstr1 (assoc 1 pt11))
(setq dlv1 (atof(cdr txtstr1)))
(princ dlv1)
(setq pts(list(car a)(cadr a)dlv1))
(setq allpt(append pts allpt))
(setvar "osmode"0)
(command "_spline")
(foreach pont allpt
(command pont)
(command "")
(command "")
(command "")
(setvar"osmode"osmd)
Perhaps:
(defun c:3dsp  (/ vLst oVar pt txt txtl allpt)
 (setq vLst '("CMDECHO" "OSMODE")
   oVar (mapcar 'getvar vLst))
 (while (and (setq pt (getpoint "\nPick Point: "))
         (setq txt (car (entsel "\nSelect Text level: "))))
    (setq txtl (atof (cdr (assoc 1 (entget txt)))))
    (princ txtl)
    (setq pt (subst txtl (last pt) pt)
      allpt (cons pt allpt)))
 (mapcar 'setvar vLst '(0 0))
 (setq allpt (append (reverse allpt) '("" "" "")))
 (command "_spline")
 (mapcar 'command allpt)
 (mapcar 'setvar vLst oVar)
 (princ))
thank you lee mack realy you are a good man
