mhy3sx Posted March 6, 2024 Posted March 6, 2024 Hi am am trying to write a very simple code but i can not understand why gives me this error Error: incorrect type - nil (defun c:cost ( / a k) (progn (setq a (getreal "\nGive Area in m2 : ")) (setq k ( / (+ (* a 2.5) 75) 1.24)) (princ (strcat "\n Calculate cost " "\n --------------------------------" "\n Area = " a " m2" "\n Cost = " (rtos k 2 2) "\n ------------------------------" ) ) ) (princ) ) Quote
mhy3sx Posted March 6, 2024 Author Posted March 6, 2024 (edited) (defun c:cost () (setq a (getreal "\nEnter Area in m2: ")) ; Get area input (setq k (/ (+ (* a 2.5) 75) 1.24)) ; Calculate cost (princ (strcat "\nCalculate cost" "\n--------------------------------" "\n Area = " (rtos a 2 2) " m2" "\n Cost = " (rtos k 2 2) "\n--------------------------------")) (princ) ) I fix it. Thanks Edited March 6, 2024 by mhy3sx 1 Quote
robierzo Posted March 7, 2024 Posted March 7, 2024 To indicate areas and volumes, lisp also accepts the superscript, using the keys Alt+0178 and Alt+0179 Quote
Steven P Posted March 7, 2024 Posted March 7, 2024 (edited) and \U+00B2 for squared or \U+00B3 for cubed as an alternative to Alt+ ("\U+.... " works better in LISP) Can also use (chr 178) and (chr 179) ... which is why LISP is brilliant - so many ways to do the same thing! "\n Area = " (rtos a 2 2) " m\U+00B2" "\n Area = " (rtos a 2 2) " m " (chr 178) Edited March 7, 2024 by Steven P 2 1 Quote
mhupp Posted March 8, 2024 Posted March 8, 2024 Usually fonts follow the same chr # but different languages or a custom font might not be the right number you can use this to find the corrrect # ;;----------------------------------------------------------------------------;; ;; Output Character ASCii number table (defun C:text_table (/ vars vals base i c tx base_n) (setq vars '(snapmode osmode cmdecho ATTDIA ATTREQ LUPREC) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars '(0 0 0 0 1 0)) ;set new values (setq base (getpoint "\nEnter Starting Point :") i 0 c 0 n (/ (getvar 'textsize) 8) H (getvar 'textsize) ) (while (< i 1000) (setq tx (strcat (AT:NumFix (itoa i) 4) " = " (chr i)) base_n (list (+ (car base) (* (fix (* (/ c 25) n)) 100)) (- (cadr base) (* 20 (* c n)))) ) (entmake (list '(0 . "TEXT") (cons 8 (getvar 'clayer)) (cons 10 base_n) (cons 40 H) (cons 1 tx) (cons 7 (getvar 'textstyle)) ) ) (setq i (1+ i)) (setq c (1+ c)) (if (eq c 25) ;simple counter to step over (progn (setq base (polar base 0 3)) (setq c 0) ) ) ) (mapcar 'setvar vars vals) ;restore old values (princ) ) (defun AT:NumFix (s n) ;; Fix number string with leading zeros ;; s - Number string to fix ;; n - Number of characters for final string ;; Alan J. Thompson, 10.29.09 ;; (AT:NumFix i 3) i= 1 = 001 (if (< (strlen s) n) (AT:NumFix (strcat "0" s) n) s ) ) 3 Quote
mhy3sx Posted March 21, 2024 Author Posted March 21, 2024 I try to add an filter in the code and now is not working . The idea is if the calculation from t1 is biger than t2 then as res1 print the t2. Can any one help me to fix it? (defun c:foo(/ *error* dch dcl des a) (defun *error* ( msg ) (if (and (= 'int (type dch)) (< 0 dch)) (unload_dialog dch) ) (if (= 'file (type des)) (close des) ) (if (and (= 'str (type dcl)) (findfile dcl)) (vl-file-delete dcl) ) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))) (princ (strcat "\nError: " msg)) ) (princ) ) (cond ( (not (setq dcl (vl-filename-mktemp nil nil ".dcl") des (open dcl "w") ) ) (princ "\nUnable to open DCL for writing.") ) ( (progn (foreach str '( "ed : edit_box" "{" " alignment = left;" " width = 20;" ;" edit_width = 10;" ;" fixed_width = true;" "}" "" "peacost : dialog" "{" " spacer;" " key = \"dcl\";" " : row" " {" " : ed { key = \"a\"; label = \"Area:\"; }" " : ed { key = \"res1\"; label = \"Calc:\"; is_enabled = false; }" " }" " : row" " {" " : ed { key = \"res2\"; label = \"Text :\"; is_enabled = false; }" " }" " spacer;" " : row" " {" " : column { width = 10;" " }" ; end column " : column { width = 17;" " : button { key = \"cal\"; label = \"Calc\"; is_default = true;" " is_cancel = false; fixed_width = true; width = 10; }" " }" ; end column " : column { width = 17;" " : button { key = \"OK\"; label = \"OK\"; is_default = true;" " is_cancel = true; fixed_width = true; width = 10; }" " }" ; end column " }" ; end row "}" ) (write-line str des) ) (setq des (close des) dch (load_dialog dcl) ) (<= dch 0) ) (princ "\nUnable to load DCL file.") ) ( (not (new_dialog "peacost" dch)) (princ "\nUnable to display 'peacost' dialog.") ) ( t (set_tile "dcl" "Any name ") (action_tile "a" "(setq a $value)") (action_tile "cal" (vl-prin1-to-string '( (lambda ( / x) (set_tile "res1" "") (set_tile "res2" "") (setq t1 (rtos (/ (+ (* e 2.5) 75) 1.24) 2 2)) (setq t2 322.58) (cond ((or (not a) (= "" a)) (alert " !!!") (mode_tile "a" 2) ) ((not (setq e (distof a))) (alert " !!!") (mode_tile "a" 2) ) ((<= e 250) (mode_tile "a" 2) (if (> t1 t2) (set_tile "res1" t1) (set_tile "res1" t2) ) (set_tile "res2" "text text text ") ) ((and (> e 250) (<= e 1000)) (mode_tile "a" 2) (if (> t1 t2) (set_tile "res1" t1) (set_tile "res1" t2) ) (set_tile "res2" "text text text") ) ((> e 1000) (mode_tile "a" 2) (if (> t1 t2) (set_tile "res1" t1) (set_tile "res1" t2) ) (set_tile "res2" "text text text") ) ) ; end cond ) ) ) ) (start_dialog) ) ) (*error* nil) (princ) ); end defun Thanks Quote
