Hi,
I try to find a dxf files only which is overlapped in multiple dxf files using API. Assist me on this. See the sample dxf.
Sample.dxfUnavailable
Hi,
This is in AutoCAD's ARX, and .NET's API
Here's a sample in Python
def PyRxCmd_doit() -> None:
    try:
        line1 = Ge.LineSeg3d(Ge.Point3d(2, 0, 0), Ge.Point3d(5, 0, 0))
        line3 = Ge.LineSeg3d(Ge.Point3d(0, 0, 0), Ge.Point3d(10, 0, 0))
        overlapResults = line1.overlap(line3)
        if not overlapResults[0]:
            print("Nope")
            return
        seg :  Ge.LineSeg3d = overlapResults[1]
        print("Overlaps from point {}, to point {}".format(
            seg.getStartPoint(), seg.getEndPoint()))
    except Exception as err:
        traceback.print_exception(err)
and the result
  Quote
Command: DOIT
Overlaps from point (2.00000000000000,0.00000000000000,0.00000000000000), to point (5.00000000000000,0.00000000000000,0.00000000000000)
Edited by Danielm103
For other objects, you might be able to check entity bounding boxes
