ajithkumar.t Posted March 6, 2024 Posted March 6, 2024 Hi, I try to find a dxf files only which is overlapped in multiple dxf files using API. Assist me on this. See the sample dxf. Sample.dxf Quote
Danielm103 Posted March 6, 2024 Posted March 6, 2024 (edited) Hi, This is in AutoCAD's ARX, and .NET's API Here's a sample in Python def PyRxCmd_doit() -> None: try: line1 = Ge.LineSeg3d(Ge.Point3d(2, 0, 0), Ge.Point3d(5, 0, 0)) line3 = Ge.LineSeg3d(Ge.Point3d(0, 0, 0), Ge.Point3d(10, 0, 0)) overlapResults = line1.overlap(line3) if not overlapResults[0]: print("Nope") return seg : Ge.LineSeg3d = overlapResults[1] print("Overlaps from point {}, to point {}".format( seg.getStartPoint(), seg.getEndPoint())) except Exception as err: traceback.print_exception(err) and the result Quote Command: DOIT Overlaps from point (2.00000000000000,0.00000000000000,0.00000000000000), to point (5.00000000000000,0.00000000000000,0.00000000000000) Edited March 6, 2024 by Danielm103 Quote
Danielm103 Posted March 6, 2024 Posted March 6, 2024 For other objects, you might be able to check entity bounding boxes Quote
