Shib Sankar Posted March 5, 2024 Posted March 5, 2024 (edited) Hi, I don't know how to make lisp.. Can anyone help me to make a lisp?? Actually in my Autocad huge rectangle available and inside each Rectangle 3 or 4 seperated text available 1 is for its dimensions (LxD) 2 is for its name and 3 is for its customer name and 4 is for its colour.. But all text are getting over lapped and making mess thus after printing its not visible.. can anyone help me to align those text into the rectangle in a sophisticated way?? Edited March 5, 2024 by Shib Sankar Forgot to give description Quote
CyberAngel Posted March 5, 2024 Posted March 5, 2024 What is the size of the rectangle? What is the height of the text style? Are those properties consistent? Where can the text be placed in the rectangle: in a column, in a row, at the corners, along the edges? Could you make it all into a block with attributes and arrange it once instead of using a function? Welcome to the forum. 1 Quote
Shib Sankar Posted March 6, 2024 Author Posted March 6, 2024 18 hours ago, CyberAngel said: What is the size of the rectangle? What is the height of the text style? Are those properties consistent? Where can the text be placed in the rectangle: in a column, in a row, at the corners, along the edges? Could you make it all into a block with attributes and arrange it once instead of using a function? Welcome to the forum. Thank you for your response.. Actually All Rectangle are in different size ( various length and width) 1. Size of rectangle : this has to be be centerd and rotated along the length . height will be 90% of as much big to fit into the rectangle area .. 2. Label name : at bottom left corner rotated along the length. hight as much big possible until overlapping with size text and rectangle border 3. Customer name : at top right corner rotated along the length. hight as much big possible until overlapping with size text , label text and rectangle. 4. Colour: pick colour name from the text available in the rectangle and recolour rectangle & all text inside the rectangle if possible Change layer with the colour name.. Quote
Shib Sankar Posted March 15, 2024 Author Posted March 15, 2024 On 06/03/2024 at 00:13, CyberAngel said: What is the size of the rectangle? What is the height of the text style? Are those properties consistent? Where can the text be placed in the rectangle: in a column, in a row, at the corners, along the edges? Could you make it all into a block with attributes and arrange it once instead of using a function? Welcome to the forum. Pls help Quote
SLW210 Posted March 15, 2024 Posted March 15, 2024 You should post a before and after example drawing. 1 Quote
Shib Sankar Posted March 18, 2024 Author Posted March 18, 2024 https://1drv.ms/i/s!AiER42EkFNJq3Rws1ujQCv1V9-2u Pls look into this photos i need this Quote
Shib Sankar Posted March 19, 2024 Author Posted March 19, 2024 https://1drv.ms/u/s!AiER42EkFNJq3R10MA6aLaivc7gm?e=i1qv6I Thanks mr. Bigal.. Pls see the attachment Quote
