I make an arc. Put it right in the middle of a circle in 2d. Orbit into 3d mode. Draw a line standing straight up. then I use the regular old rotate command using a reference to stand the arc up next to the line, erase the line. Then I use extrude, select the object (circle) select the path option. click on the arc and BAM. A 90 degree Ell is there.
Could be an easy way but it works for me
  • Replies 20
  • nialb
    4
  • L_Ruts
    4
  • Cunoblin
    4
  • adirondackbell
    2
Posted Images
