Better Elevation of Roof Tiles Covering
nicolas
HI,
I am looking for some feedback on improving the roof tiles covering.  Your inputs are most welcomed. Thanks.
I am also looking for some decorative window surround like in the attached picture.  If any of you can forward same to me, I will be most grateful.
Thanks.
GroundFloorLayout.pdf RoofLayout.pdf RoofTiles 00.dwg RoofTiles_Elevation.pdf
I moved your thread to the AutoCAD 3D Modelling & Rendering Forum.
Feedback is not a place to post your work and ask for recommendations, it for feedback about the CADtutor forum as noted in the description.
Quote
Feedback
Tell me what you think of CADTutor.net and the forum. Let me know what you'd like to see in the future. Could it be improved?
Re: decorative window surround.  What you are looking for is concrete trim molding for windows.  Suncoast Stone and Laguna Precast are two suppliers for such products.  Your depiction of roof tiles looks fine to me.  What's the problem?  BTW... the roof tiles are referred to as Spanish tile, barrel tile roofing and clay barrel tile.  One supplier is Brava Roof Tile.
Edited by ReMark
  • 3 months later...
On 3/4/2024 at 8:51 AM, nicolas said:
HI,
Thanks.
GroundFloorLayout.pdf 127.76 kB · 2 downloads RoofLayout.pdf 115.45 kB · 1 download RoofTiles 00.dwg 639.67 kB · 2 downloads RoofTiles_Elevation.pdf 204.28 kB · 1 download
Metal roofing tiles
I am creating a House in 3ds. I need to put Roof tiles on that roof though, how do you guys recommend I do that? I don't want to put a simple texture, I am aiming for photorealism. Any help is appreciated. Thanx
Replicating roof tiles on your house, in 3D, instead of using a texture map could significantly increase the file size.
I would probably use a roof texture with a normal map or maybe a displacement map if you want more realism. Having all those individual roof tiles could cause your system to bog down.
But, if you want to do the roof tiles, and you're using 3ds Max, you could take a look at this maxscript plugin for creating roof tiles: http://www.scriptspot.com/3ds-max/scripts/avizstudio-tools-atiles
  • 2 weeks later...
Regarding the decorative window surround in the attached picture, it looks like a stylish and classic design with a stone or concrete finish. You might want to check with local suppliers of architectural stone products or masonry companies. They often have a range of decorative elements like the one in your image. Additionally, many home improvement stores or specialty websites offer custom orders for such decorative surrounds.
Let me know if you need more detailed information or have other questions!
Thanks.
