ymg3 Posted March 29 Posted March 29 (edited) Here's my take. ;; cone_batter by ymg ; ;; ; ;; Note that ssb remains global and is the selection set of batters, ; ;; At a selection prompt enter !ssb ; ;; ; ;; Prog requires function midpoint. ; ;; ; (defun c:cone_batter (/ ent1 ent2 p1 p2 cum1 cum2 len1 len2 n_bat n i) (setq ent1 (car (entsel "\n Select a TOP polyline: ")) ent2 (car (entsel "\n Select a BOTTOM polyline: ")) n_bat (getint "\n How many batter tics: ") n (+ 1 n_bat) ) (setq len1 (/ (vlax-curve-getdistatparam ent1 (vlax-curve-getendparam ent1)) n) len2 (/ (vlax-curve-getdistatparam ent2 (vlax-curve-getendparam ent2)) n) cum1 0.0 cum2 0.0 i 0 ssb (ssadd) ) (repeat (+ n 1) (setq p1 (vlax-curve-getPointAtDist ent1 cum1) p2 (vlax-curve-getPointAtDist ent2 cum2) ) (if (zerop (rem i 2)) (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2))) (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 (midpoint p1 p2)))) ) (ssadd (entlast) ssb) (setq cum1 (+ cum1 len1) cum2 (+ cum2 len2) i (+ i 1) ) ) ) ;; Function midpoint by ymg ; ;; Returns the midpoint between 2 points. ; (defun midpoint (a b) (polar a (angle a b) (* (distance a b) 0.5))) ymg cone_batter.lsp Edited March 30 by ymg3 Commented the code and re-uploaded 2 Quote
shahAbdul Posted April 2 Posted April 2 @BIGALi have use batterticks.lsp but not function... in my autocad type tbl.. and notice " enter spacing of tick" i enter and notice display "select the batter top" i klik line on object and notice "select the opposite site"...when enter only one long line appear Quote
devitg Posted April 2 Posted April 2 6 hours ago, shahAbdul said: @BIGALi have use batterticks.lsp but not function... in my autocad type tbl.. and notice " enter spacing of tick" i enter and notice display "select the batter top" i klik line on object and notice "select the opposite site"...when enter only one long line appear @shahAbdul Please upload both DWG and Lsp you use. Quote
BIGAL Posted April 4 Posted April 4 The batter tick spacing is how far along the top object the tick is placed so if an arc is say 10 long a spacing of 2.5 should work. Quote
shahAbdul Posted April 5 Posted April 5 @BIGAL i use 2.5 for spacing but not function..notice error display ' autocard applacation: filer error' Quote
zwonko Posted April 5 Author Posted April 5 @shahAbdul Without file with the problem We can't help You Quote
devitg Posted April 5 Posted April 5 12 hours ago, shahAbdul said: i use 2.5 for spacing but not function..notice error display ' autocard applacation: filer error' @shahAbdul you need this block at your dwg Quote
