To help us out, does the script just not work, or does it return any errors. Second question, what is the LISP meant to do?
Did this ever work properly? There are a couple of things in the LISP that need fixing
Expand
it works with autocad 2007, can you fix it for me?
Try this:
(defun c:clo ( / )
  ;;Add in error function in the case of cancelling, OS mode resets to as before
  (defun MyBoundary ( pt / ) (command "-BOUNDARY" pt "")(entlast)) ; to catch errors in boundary creation
  (defun RtD (r / ) (* 180.0 (/ r pi)))          ; Radians to degrees
  (defun LM:vl-setattributevalue ( blk tag val ) ; Set attribute
    (setq tag (strcase tag))
    (vl-some
       '(lambda ( att )
            (if (= tag (strcase (vla-get-tagstring att)))
                (progn (vla-put-textstring att val) val)
        (vlax-invoke blk 'getattributes)
  (defun LM:str->lst ( str del / pos )         ; split text
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
        (list str)
  (setq el (entlast))
  (princ "Select Block: ")
  (setq OS_Old (getvar 'osmode))
  (setq bm (ssget "_+.:E:S" '((0 . "INSERT"))))        ; filter to single block
  (setq bn     (cdr (assoc 2 (entget (ssname bm 0))))) ; block name
  (setq Tenlo  (cdr (assoc 1 (entget (entnext (entnext (ssname bm 0))))))) ; Text value
  (setq TagName1 (cdr (assoc 2 (entget (entnext (ssname bm 0)))))); Attribute Name
  (setq TagName2 (cdr (assoc 2 (entget (entnext (entnext (ssname bm 0))))))); Attribute Name
  (setq splittext (LM:str->lst Tenlo ":"))             ; text splt at :
  (setq tengoc (last splittext))                       ; Text 'number'
  (setq stt    (getint "\nso lo dat bat dau: / Enter Value: "))
  (while (setq pt (getpoint "\npick diem: / Internal Point: "))   ; loop while points are selected
    (vl-catch-all-apply 'MyBoundary (list pt))
    (setq elSS (ssadd (entlast)))
    (if (/= el nil) (setq elSS (ssadd el elSS)) )
    (if (and (/= el nil)(= (sslength elSS) 1) )
        (princ "\nNot enough boundary")
        (setvar 'osmode 512)                               ;set snap mode
        (setq p1 (getpoint "\nChon diem 1: Point on Boundary 1: "))   ; get point 1
        (setq p2 (getpoint p1 "\nChon diem 2: Point on Boundary 2: ")); get point 2
        (setvar 'osmode OS_Old)                            ; reset snap mode
        (setq ang (angle p1 p2))                           ; angle in radians
        (setq area (vlax-curve-getArea (entlast)))         ; get area. Error if no boundary created
        (setq st (if (< stt 10)                            ; leading zero
                   (strcat "0" (rtos stt))
                   (rtos stt)
        (entdel (entlast))                                ; delete boundary. Error if no boundary
        (setq ang (+ ang (/ pi 2)))
        (if (> ang pi)
          (setq ang (- ang pi))
;;Insert Block
        (command "insert" bn pt 1 1 (RtD ang))
;;Set attributes
        (LM:vl-setattributevalue (vlax-ename->vla-object (entlast)) TagName2 (strcat (car splittext) ":" st))
        (LM:vl-setattributevalue (vlax-ename->vla-object (entlast)) TagName1 (rtos area 2 1))
        (setq el (entlast))
        (setq stt  (+ stt 1))
      ) ; end progn
    ) ; end if boundary
  ) ; end while
