AUTOCAD IS MY LIFE Posted February 28 Share Posted February 28 the work click every block to edit the properties (size, layer, fonts) of text is very slowly. Do you have a Lisp code that can adjust properties texts within different blocks and edit them all at once? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 28 Share Posted February 28 Please, do not post all over the forum for the same question. 1 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted February 28 Share Posted February 28 Take a look at this series of functions for editing attribute properties. You can probably adapt one of them to edit text properties by changing the loop test. Here's another function that (I think) does a global style change, even inside blocks. With a little tweaking, it should do the same for all the other properties you want to change. If these don't help, please provide more information about your goals. Welcome to the forums! 1 Quote Link to comment Share on other sites More sharing options...
AUTOCAD IS MY LIFE Posted February 29 Author Share Posted February 29 THANKYOU VERY MUCH! MY PROBLEM IS SOLVED Quote Link to comment Share on other sites More sharing options...
