Copy Move and Scale in Autocad through VB.net
Hi everyone,
I'm relatively new to VB and AutoCAD, and I've been trying to incorporate a command line method into my existing code to copy, move, and scale a drawing. However, I've hit a roadblock and would appreciate some guidance.
Every time I try to run the code, I encounter an error stating "acdbmgd.dll not found." From what I understand, this seems to be related to a missing reference or dependency associated with AutoCAD libraries.
Here's  the code I've been working on:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Public Class SelectionSetClass
    <CommandMethod("SelectWindowAndCopy")>
    Public Sub SelectWindowAndCopy()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim edt As Editor = doc.Editor
        Using trans As Transaction = doc.TransactionManager.StartTransaction()
            Dim psr As PromptSelectionResult = edt.SelectWindow(New Point3d(36, 22, 0), New Point3d(149.5, 33, 0))
            If psr.Status = PromptStatus.OK Then
                Dim ss As SelectionSet = psr.Value
                ' Get the bottom-left corner of the window selection
                Dim windowBottomLeft As Point3d = New Point3d(35, 22, 0)
                For Each sobj As SelectedObject In ss
                    Dim ent As Entity = TryCast(trans.GetObject(sobj.ObjectId, OpenMode.ForWrite), Entity)
                    If Not ent Is Nothing Then
                        '' Create a copy of the selected entity
                        Dim entCopy As Entity = ent.Clone()  ' Create a copy of the entity
                        '' Calculate the translation vector to move the bottom-left corner of the entity to the origin
                        Dim translationVector As Vector3d = New Vector3d(-windowBottomLeft.X, -windowBottomLeft.Y, 0)
                        '' Apply the translation transformation
                        entCopy.TransformBy(Matrix3d.Displacement(translationVector))
                        '' Apply the scaling transformation
                        Dim scaleMatrix As Matrix3d = Matrix3d.Scaling(10, New Point3d(0, 0, 0))
                        entCopy.TransformBy(scaleMatrix)
                        '' Open the Block table for write
                        Dim acBlkTbl As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
                        Dim acBlkTblRec As BlockTableRecord = trans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                        '' Add the copied entity to the block table record
                        acBlkTblRec.AppendEntity(entCopy)
                        trans.AddNewlyCreatedDBObject(entCopy, True)
                    End If
                Next
            End If
            trans.Commit()
        End Using
    End Sub
End Class
I've tried researching this issue online, but I'm still unsure how to resolve it. Can anyone please provide insights on how I can properly reference the required AutoCAD libraries in my project settings to fix this error?
Any help or suggestions would be greatly appreciated.
Thank you in advance!
Edited by SLW210
Code Tags!
Please use Code Tags in the future. (<> in the editor toolbar)
acdbmgd.dll is associated with the DatabaseServices library. It's kind of important, because a drawing is basically a database full of objects.
See this discussion. If you're creating an EXE, you can't use .NET, if I'm reading it correctly. There is some good advice on how to work with VBA.
If that doesn't take care of your issue, please provide more information.
Welcome to the forum!
Perhaps this discussion as well.
Quote
From taking programming classes led by some of the head developers from Autodesk they said to always reference the acmgd & acdbmgd dlls from the ObjectARX sdk (not the one delivered with the software) and to NOT deliver them with your own applications.
