forurunni Posted March 2, 2009 Posted March 2, 2009 My ddarea lisp worked well in Autocad 2008 but it doesn't work in Autocad 2009 what should i do ? please give me a reply ......... Quote
rkmcswain Posted March 2, 2009 Posted March 2, 2009 What kind of error do you get? Does the error occur when the lisp file is loaded or when the function is executed? Quote
Lee Mac Posted March 3, 2009 Posted March 3, 2009 As rkmcswain says, its hard to tell exactly whats going wrong having not seen the LISP or knowing what error it returns. But there can't be much difference between running it on '08 as opposed to '09. I doubt there were too many sys var changes, or command prompt changes that could cause an error. If indeed it is a sys var change, you can check it here Quote
