symoin Posted February 23, 2024 Posted February 23, 2024 Hi, is there any code that will help in erasing selected objects on model space , either by selecting individual object or by window. Then the same objects or all objects with the area of window should be deleted from all the drawings in a folder or from the selected drawings. Some thing like a batch lisp. Thanks Quote
BIGAL Posted February 24, 2024 Posted February 24, 2024 (edited) The erase by window can be done, if you look into using SCRIPT, it can do what you want to multiple dwg's, its just take the steps you would do manually and put them into a file. myerasewindow.SCR Open dwg erase objects close and save. Repeat next dwg Hey that is a script ! Edited February 24, 2024 by BIGAL 1 Quote
