DaveB Posted February 22 Posted February 22 (edited) I am building a .NET app for ACAD 2024 and have a question about dependent DLLs. In the Initialize method of my IExtensionApplication app I have this... public void Initialize() { var editor = AcadLib.Instance.Editor; editor.WriteMessage("\nLoading SuperDuperApp v2024.2... "); try { var executingAssemblyLocation = Assembly.GetExecutingAssembly().Location; var baseDirectory = Path.GetDirectoryName(executingAssemblyLocation); editor.WriteMessage("\nSuperDuperApp Support Assemblies... "); // support assemblies TryToLoadAssembly($"{baseDirectory}\\Csv.dll"); TryToLoadAssembly($"{baseDirectory}\\CommonServiceLocator.dll"); This way I should only need to load the top level DLL (automatically, or otherwise) and everything dependent loads during initialization. This is a WPF app living in a palette set and using MVVM. I am using the older Galasoft MVVMLight library because I've found ACAD really doesn't like the newer community version. Too bad. That CommonServiceLocator is being a problem though. If I don't have the directory with my app in it in the support file search path, ACAD complains that my ViewModelLocator class can't find the CommonServiceLocator, despite it being pre-loaded into the .NET sandbox. Is there a way to specify a search location or should I just let everything load on demand by going through the support search path? Edited February 22 by DaveB Quote
