Is anyone able to help
In vb.net how do i find the angle of the tangent line to a curve at a given point relative to the X axis?
Also would this have to be quadrant sensitive?
Don't know vb.net, but the function/expression you need is the "arc tangent", so look for something like that. In lisp it's "atan". And yes it's quadrant sensitive, positive tangent would give you a 0-90 degree result, negative is for a 90-180 degrees.
**edit** found this, might help:
This example uses the Atan method of the Math class to calculate the value of pi.
Public Function GetPi() As Double
   ' Calculate the value of pi.
   Return 4.0 * Math.Atan(1.0)
End Function
The general methodology for 3d curves would be:
1. Select the curve
2. Pick a point(Point3d) on the curve with (DatabaseServices.Curve.GetClosestPointTo)
3. Get first derivative(Geometry.Vector3d) with(DatabaseServices.Curve.GetFirstDerivative (Geometry.Point3d))
4. Get angle with System.Math.Atan(Geometry.Vector3d.Y/Geometry.Vector3d.X)
ahh thank you very much
so how do i calculate what quadrant it is in so that i can calculate the 'Normal to the tangent'.?
Tan is positive for quadrants 1 and 3 and negative for quadrants 2 and 4, hence a positive result indicates a vector at 0-pi/2 to the x-axis, plus or minus pi; and negative pi/2 - pi, plus or minus pi.
I suppose you could add coding to correct the angle by pi radians so that you will only get an answer between 0 and pi, then the normal to the tangent will just be the arctan + pi/2.
Is this a purely 2D problem, or are you interested in the Binormal to the tangent also?
No its purely 2d.
Thanks for that - i changed the code around so it will work now.
This is what i have.
[size=2][color=#0000ff]Public Function [/color][/size][size=2]CalcAngle([/size][size=2][color=#0000ff]ByVal [/color][/size][size=2]ObjCurve [/size][size=2][color=#0000ff]As [/color][/size][size=2]AcadNetDbServices.Curve, [/size][size=2][color=#0000ff]ByVal [/color][/size][size=2]Dist [/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#6f002f]Double[/color][/size][size=2])
[/size][size=2][color=#008000]
[/color][/size][size=2][color=#0000ff]Dim [/color][/size][size=2]Radians [/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#6f002f]Double
[/color][/size][size=2][color=#0000ff]Dim [/color][/size][size=2]Degrees [/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#6f002f]Double
[/color][/size][size=2][color=#0000ff]Dim [/color][/size][size=2]Point1 [/size][size=2][color=#0000ff]As [/color][/size][size=2]AcadNetGeometry.Point3d = ObjCurve.GetPointAtDist(Dist)
[/size][size=2][color=#0000ff]Dim [/color][/size][size=2]firstderiv [/size][size=2][color=#0000ff]As [/color][/size][size=2]AcadNetGeometry.Vector3d = ObjCurve.GetFirstDerivative(Point1)
Radians = Math.Atan2([/size][size=2][color=#0000ff]Cdbl[/color][/size][size=2](firstderiv.Y) , [/size][size=2][color=#0000ff]Cdbl[/color][/size][size=2](firstderiv.X))
Degrees = Radians * (180 / Math.PI)
[/size][size=2][color=#008000]'If in positive quadrants then = 180 - abs.Degrees
'If in Negative quadrants then = Abs.Degrees - 180
[/color][/size][size=2][color=#0000ff]If [/color][/size][size=2]Degrees < 0 [/size][size=2][color=#0000ff]Then
[/color][/size][size=2]Degrees = (Math.Abs(Degrees)) + 180
[/size][size=2][color=#0000ff]Else
[/color][/size][size=2]Degrees = 180 - (Math.Abs(Degrees))
[/size][size=2][color=#0000ff]End If
[/color][/size][size=2]CalcAngle = Degrees
[/size][size=2][color=#0000ff]End Function
[/color][/size]
Not sure why you would set Degrees = 180 - angle for any positive result. Say it was initially calculated at 45 degrees, wouldn't that be a good answer already? But then I don't know what you're using it for...
I don't know much about vb.net (in fact I know absolutely nothing about it), but when you find the first derivative, does that not return a vector? - Then you would know exactly the direction of the tangent from the vector.
derivative gives the slope of the tangent.
using atan2 gets the arc tangent to it.
also i had to use Degrees = 180 - Angle in the positive quadrant because i was getting answers like 175 & 115 when it should be 5 & 65 etc
Thanks for your help guys.
This works
This works
Ok, glad it works for you Russell - just offering other suggestions :thumbsup:
Lee
some more angles for whoever is interested.
[size=2][color=#008000]'If you want the the angle between the line defined by these two points and the horizontal axis:[/color][/size]
[size=2][color=#0000ff]Public Function [/color][/size][size=2]DoubleAngle ([/size][size=2][color=#0000ff]ByVal [/color][/size][size=2]Point1 [/size][size=2][color=#0000ff]As [/color][/size][size=2]AcadNetGeometry.Point3d, [/size][size=2][color=#0000ff]ByVal [/color][/size][size=2]Point2 [/size][size=2][color=#0000ff]As [/color][/size][size=2]AcadNetGeometry.Point3d) [/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#6f002f]Double[/color][/size]
[size=2]DoubleAngle = math.Atan2(Point2(1) - Point1(1),Point2(0) - Point1(0)) [/size][size=2][color=#008000]'Answer in Radians[/color][/size]
[size=2][color=#0000ff]End Function[/color][/size]
[size=2][color=#008000]'If you want the angle bewteen the vectors OP1 and OP2 (O being the origin), you should know that the dot product between two vectors u and v is:[/color][/size]
[size=2][color=#008000]'u . v = u.x * v.x + u.y * v.y = |u|*|v|*cos(a)[/color][/size]
[size=2][color=#008000]'a being the angle between the vectors.[/color][/size]
[size=2][color=#008000]'So the angle is given by:[/color][/size]
[size=2][color=#008000]'double n1 = sqrt(x1*x1+y1*y1), n2 = sqrt(x2*x2+y2*y2);[/color][/size]
[size=2][color=#008000]'double angle = acos((x1*x2+y1*y2)/(n1*n2));[/color][/size]
[size=2][color=#0000ff]Public Function [/color][/size][size=2]AngleBetweenVectors([/size][size=2][color=#0000ff]ByVal [/color][/size][size=2]Point1 [/size][size=2][color=#0000ff]As [/color][/size][size=2]AcadNetGeometry.Point3d, [/size][size=2][color=#0000ff]ByVal [/color][/size][size=2]Point2 [/size][size=2][color=#0000ff]As [/color][/size][size=2]AcadNetGeometry.Point3d) [/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#6f002f]Double[/color][/size]
[size=2][color=#0000ff]Dim [/color][/size][size=2]N1 [/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#6f002f]Double[/color][/size]
[size=2]N1 = Math.Sqrt(Math.Pow(Point1(0), 2) + Math.Pow(Point1(1), 2))[/size]
[size=2][color=#0000ff]Dim [/color][/size][size=2]N2 [/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#6f002f]Double[/color][/size]
[size=2]N2 = Math.Sqrt(Math.Pow(Point2(0), 2) + Math.Pow(Point2(1), 2))[/size]
[size=2][color=#0000ff]Dim [/color][/size][size=2]AngleTemp [/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#6f002f]Double [/color][/size][size=2]= Math.Acos((Point1(0) * Point2(0) + Point1(1) * Point2(1)) / (N1 * N2)) [/size][size=2][color=#008000]'(in radians) * 180/MATH.PI to get degrees[/color][/size]
[size=2][color=#008000][size=2][color=black]AngleBetweenVectors = AngleTemp[/color][/size]
[/color][/size][size=2][color=#0000ff]End Function[/color][/size]
[size=2][color=#0000ff][size=2][color=#008000]'To get the Tangent vector to a curve at a given point (StartPt1) example[/color][/size]
[size=2][color=#0000ff]Dim [/color][/size][size=2][color=#000000]VectorTangent1 [/color][/size][size=2][color=#0000ff]As [/color][/size][size=2][color=#000000]AcadNetGeometry.Vector3d = TopCurve.GetFirstDerivative(StartPt1)[/color][/size]
[size=2][color=#008000]'To get the Normal vector (Perp) to the vectorTangent[/color][/size]
[size=2][color=#0000ff]Dim [/color][/size][size=2][color=#000000]VectorNormal1 [/color][/size][size=2][color=#0000ff]as [/color][/size][size=2][color=#000000]AcadNetGeometry.Vector3d = [/color][/size][size=2][color=#0000ff]New [/color][/size][size=2][color=#000000]AcadNetGeometry.Vector3d(-VectorTangent1.Y, VectorTangent1.X, VectorTangent1.Z)[/color][/size]
[/color][/size]
If there are any more additions or suggestions please post.
Thanks
All good stuff. 8)
One suggestion regarding this code:
Dim VectorNormal1 as AcadNetGeometry.Vector3d = New AcadNetGeometry.Vector3d(-VectorTangent1.Y, VectorTangent1.X, VectorTangent1.Z)
I know you mentioned earlier that the focus was mainly on 2d, but with 3d certain situation may return less than ideal result. The most obvious of which would be a case where the tangent vector is aligned with the World Z i.e., 0,0,1. The return would also be 0,0,1
In general, I suspect the most useful return from such a query would be a vector perpendicular to the tangent vector, but also lying in the same plane as “TopCurve” (if, indeed, TopCurve is a planar curve). A good approach to satisfy that refinement would be to get the Cross Product of TopCurve.Normal and VectorTangent. See attachment.
I suppose to be truly 3d compliant the vector tangent normal would always point to the center of curvature for even non-planar curves. Definitely an extra credit style of problem. :geek:
CrossProduct.dwg
I suppose I should also point out that my statement:
is not particularly 3d compliant. It would return the angle between the X axis and the vector’s projection to the WCS (I guessed that was what you were looking for in your original post). :ouch:
The true 3d angle between those two vectors would have to account for the Vector3d.Z component. Vector3d.GetAngleTo Method (X axis as Vector3d).
