Lee Mac Posted February 28, 2009 Posted February 28, 2009 Hi Guys, Was trying to help another user in the ACAD General Forum who wanted to draw a spline midway between two other splines. I made a LISP that would construct a pline midway between the splines, but couldn't stop it from endlessly looping... This is driving me up the wall, as its a relatively simple LISP and not much could really go wrong... (defun c:off (/ vLst oVar aEnt bEnt acy i pnt nrpnt) (vl-load-com) (setq vLst (list "CMDECHO" "OSMODE" "CLAYER") oVar (mapcar 'getvar vLst)) (setvar "CMDECHO" 0) (setvar "OSMODE" 0) (if (not (tblsearch "LAYER" "INTERMEDIATE")) (command "-layer" "M" "INTERMEDIATE" "_C" "15" "INTERMEDIATE" "") (setvar "CLAYER" "INTERMEDIATE")) (if (and (setq aEnt (car (entsel "\nSelect First Contour... ")) bEnt (car (entsel "\nSelect Second Contour..."))) (= "SPLINE" (cdadr (entget aEnt)) (cdadr (entget bEnt)))) (progn (setq acy 10.0 i 1.0) (command "_pline") (while (setq pnt (vlax-curve-GetPointAtDist aEnt (* i acy))) (setq nrpnt (vlax-curve-GetClosestPointTo bEnt pnt)) (command (polar pnt (angle pnt nrpnt) (/ (distance pnt nrpnt) 2))) (setq i (1+ i))) (command)) (princ "\nNo Spline Selected or this isn't a Spline...")) (mapcar 'setvar vLst oVar) (princ)) Any help is much appeciated as always Cheers Lee Quote
CarlB Posted February 28, 2009 Posted February 28, 2009 Perhaps "vlax-curve-GetPointAtDist " keeps returning a value even when distance is longer than line length. If so, first determine spline/curve length, then base loop on distance Quote
Lee Mac Posted February 28, 2009 Author Posted February 28, 2009 I think you may be right there Carl, I have tested it with Polylines, Lines etc and it works to perfection, just not with splines... May have to use the method you suggested. Thanks Quote
