muck Posted February 28, 2009 Posted February 28, 2009 If AutoDesk is going to remove VBA from release 2010, What are some good programs to use with current releases of CAD (2000 to 2009) to help migrate form VBA to new AutoCAD VSTA which will be in AutoCAD 2010? Can MS visual studio express edition be used with AutoCAD 2009. If so, how can Visual Basic.net be linked to older releases of AutoCAD? Can that be done and would it help those who want to learn how to change their current VBA routines. What options are available now for those who want learn how to migrate form VBA in older releases of AutoCAD. What is AutoCAD.net? Is there something that I can currently do that start learning for the upcoming changes. Maybe it might be time to consider learning other languages in order to reprogram my lisp routines in the distant future. Are the any options available now. Quote
SEANT Posted March 1, 2009 Posted March 1, 2009 I don’t believe we will see VSTA before 2011, at least. Till then, Visual Studio programming will require NETLOADing (or ARX – LOAD) AutoCAD 2005 was the first release that allowed for .NET programming. I believe significant change happened in AutoCAD 2006, however, that modified the approach to the point that programs compatible with 2006+ would not work on 2005. For the most part, .NET programs should be backward/forward compatible (i.e., 2006 programs run on 2010). If support for pre 2005 is necessary, as well as compatibility beyond the lifecycles of both Lisp and VBA(when?), then C++ (unmanaged ObjectARX) is likely necessary. And, even then, code would need separate compiles for each binary release (2000, 2004, 2007, 2010, ….). Quote
muck Posted March 1, 2009 Author Posted March 1, 2009 So if you installed 2009 on a machine. What do you need to do net AutoCAD programming. What net programs do you need. How do you link them. Is there a beginning tutorial on this??? Thank you, Quote
SEANT Posted March 1, 2009 Posted March 1, 2009 So if you installed 2009 on a machine. What do you need to do netAutoCAD programming. What net programs do you need. How do you link them. Is there a beginning tutorial on this??? Thank you, Visual Studio 2005 or 2008, including the Express Edition (free). With Express, this link may be of some interest: http://discussion.autodesk.com/forums/thread.jspa?threadID=716827&tstart=0 And for the general help with .NET: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627 and http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550 Quote
muck Posted March 1, 2009 Author Posted March 1, 2009 If you have both MS visual Studio.net and AutoCAD 2009 on the same machine can you link the two together to allow the Ms visual Studio.net to access AutoCAD for programming. Is that what ARX is for? Is there some kind of tutorial on that introductary stuff? Quote
SEANT Posted March 1, 2009 Posted March 1, 2009 If you have both MS visual Studio.net and AutoCAD 2009 on the samemachine can you link the two together to allow the Ms visual Studio.net to access AutoCAD for programming. Absolutely. Is there some kind of tutorial on that introductary stuff? The video DevTV: Introduction to AutoCAD .NET Programming on the &id= 1911627 link above is a good intro. Quote
Organic Posted March 2, 2009 Posted March 2, 2009 So is it worth learning LISP or not, or should I learn something else? Quote
SEANT Posted March 2, 2009 Posted March 2, 2009 So is it worth learning LISP or not, or should I learn something else? That depends. This thread had a very similar question: http://www.cadtutor.net/forum/showthread.php?t=28448 Quote
muck Posted March 3, 2009 Author Posted March 3, 2009 I have used both VBA and Lisp. I think lisp is more direct way to program CAD but who knows its future after release 2010. I hope they keep it in future releases. I started with lisp with version 10 or 11 and I still use those routines. Quote
Lee Mac Posted March 3, 2009 Posted March 3, 2009 I found LISP more accessible and also more intuitive to learn - although its applicability to other programs is very limited. Quote
muck Posted March 4, 2009 Author Posted March 4, 2009 I found a good Pdf file on the net that is a good but I cant' find parts 1 and 3. Does anyone have parts 2 and 3 of the attached pdf file. I went thur part 1. Quote
Lee Mac Posted March 4, 2009 Posted March 4, 2009 Muck, I think you forgot to provide the attachment... Quote
muck Posted March 4, 2009 Author Posted March 4, 2009 The document that I am going thru, is too large to post. It is called Autocad.Net Baisics by Stephn Preston. It is a 11 page document. I have part 1 but I don't have parts 2 and 3. I down loaded it form a google search link that does not have a formal webpage. Part one was a good tutorial for Hello World type of program. I wish I could find parts 2 and 3 to continue. Is was from AutoDesk University 2007. I am also thinking the object model will be much different than VBA object model so I will probably be looking for a book on this topic. Thank you, Quote
Organic Posted March 4, 2009 Posted March 4, 2009 Part 2, first link http://www.google.com.au/search?hl=en&q=Autocad.net+basic+stephen+preston+part+2&btnG=Search&meta= Quote
JohnM Posted March 5, 2009 Posted March 5, 2009 I think AutoCAD will keep lisp because they control the engine where as Microsoft controls VB. If they get rid of lisp a whole lot of us will be going postal then jumping out of windows. The question I have is since visual lisp uses vl- functions, which is access to VB functions, will it be gone? C++ is cool but a pain to compile for each time they change gears at AutoDesk I think we need a petition to let AutoDesk know what we think and they should cater to all of are needs not their own. It is people like us that create new programs and AutoDesk incorporates some of them into future versions which makes them better Well that’s my 2 cents (after taxes for the bail out that’s -$5,999.98) Quote
muck Posted March 5, 2009 Author Posted March 5, 2009 Thank you Dink87522. That is part 2 of the part 1 that I was going throught If you know how to get part 3 please let me know. It will take me a little time to get thru that information. Hopefully before 2010 is released. I think I will look at it this weekend. Quote
CarlB Posted March 5, 2009 Posted March 5, 2009 Reading the intro, there is only a Part 1 & Part 2. There were other net docs though; DE115-2 – AutoCAD .NET Basics, Part II DE205-2 – AutoCAD® .NET Show and Tell DE201-2 – AutoCAD® .NET: Tell Me About It! DE211-2 – The Best of Both Worlds: .NET and LISP Can Coexist ..which can be downloaded by altering the end of the "part 1" link below with the session numbers. http://augiru.augi.com/content/library/au07/data/paper/DE111-2.pdf Quote
muck Posted March 5, 2009 Author Posted March 5, 2009 What books do you recommend for AutoCAD.net programming? Quote
muck Posted March 6, 2009 Author Posted March 6, 2009 Part two of AutoDesk University artical mentions name spaces. What is a Namespace? Looks like there will be a lot more involved in making drawing changes with AutoCAD.net than VBA for CAD. Looks like you will have to set up a new transaction and comiit it to make small changes. Looks like a lot to make drawing changes. Thank you, Quote
