eldon Posted February 28, 2009 Posted February 28, 2009 In the attached picture, you can see that if I offset the spline at -25.00 contour, there are many more grip points. I turned the -20.00 contour to a polyline, by using FLATTEN in Express Tools, and then offset it, and you can see that there are fewer grip points. Then use PEDIT, and decurve the polyline and there are even fewer grip points. You can now move these points where you want them. When you have moved them, then use PEDIT, and fit a curve. I have given you all the commands that you need, and now you have to find out these commands and learn. :wink: Quote
casualmasters Posted February 28, 2009 Author Posted February 28, 2009 In the attached picture, you can see that if I offset the spline at -25.00 contour, there are many more grip points. I turned the -20.00 contour to a polyline, by using FLATTEN in Express Tools, and then offset it, and you can see that there are fewer grip points. Then use PEDIT, and decurve the polyline and there are even fewer grip points. You can now move these points where you want them. When you have moved them, then use PEDIT, and fit a curve. I have given you all the commands that you need, and now you have to find out these commands and learn. :wink: thank you very very much Quote
Lee Mac Posted February 28, 2009 Posted February 28, 2009 Hope you get it all sorted... meanwhile, I'm going to see if I can fix that LISP I posted... Quote
Lee Mac Posted February 28, 2009 Posted February 28, 2009 After flattening your Splines, try this: (defun c:off (/ vLst oVar aEnt bEnt acy i pnt nrpnt) (vl-load-com) (setq vLst (list "CMDECHO" "OSMODE" "CLAYER") oVar (mapcar 'getvar vLst)) (setvar "CMDECHO" 0) (setvar "OSMODE" 0) (if (not (tblsearch "LAYER" "INTERMEDIATE")) (command "-layer" "M" "INTERMEDIATE" "_C" "15" "INTERMEDIATE" "") (setvar "CLAYER" "INTERMEDIATE")) (if (and (setq aEnt (car (entsel "\nSelect First Contour... ")) bEnt (car (entsel "\nSelect Second Contour..."))) (= "LWPOLYLINE" (cdadr (entget aEnt)) (cdadr (entget bEnt)))) (progn (setq acy 10.0 i 1.0) (command "_pline") (while (setq pnt (vlax-curve-GetPointAtDist aEnt (* i acy))) (setq nrpnt (vlax-curve-GetClosestPointTo bEnt pnt)) (command (polar pnt (angle pnt nrpnt) (/ (distance pnt nrpnt) 2))) (setq i (1+ i))) (command)) (princ "\nNo Polyline Selected or this isn't a Polyline...")) (mapcar 'setvar vLst oVar) (princ)) Quote
