Tsuky Posted February 26, 2024 Posted February 26, 2024 @pmadhwal7 See the video, how i use it. 2024-02-26 11-12-10.mkv Quote
pmadhwal7 Posted February 26, 2024 Author Posted February 26, 2024 41 minutes ago, Tsuky said: @pmadhwal7 See the video, how i use it. 2024-02-26 11-12-10.mkv 1.85 MB · 2 downloads thanks i was try firstly on small file and it worked,i tried next file but same issue faced hang the autocad Library _ Loom - 26 February 2024.mp4 Quote
Tsuky Posted March 3, 2024 Posted March 3, 2024 @pmadhwal7 Please, give me the drawing exemple for help me to identifie the bug, if I can... Quote
pmadhwal7 Posted March 4, 2024 Author Posted March 4, 2024 On 3/3/2024 at 8:46 AM, Tsuky said: @pmadhwal7 Please, give me the drawing exemple for help me to identifie the bug, if I can... Actually not any particular file but facing in every file, file attached please check LENGTH.dwg Quote
Tsuky Posted March 4, 2024 Posted March 4, 2024 @pmadhwal7 Here's an improved version that should work better. But before using it, an overlap inconsistency between 2 polylines exists in your drawing that you must correct. To help you locate them, copy/paste these two lines successively and make the desired correction. (redraw (handent "2FD") 3) (redraw (handent "2FE") 3) On the other hand I noticed many duplicate vertices on many polylines especially at the start and/or at the end, this does not pose a problem for the program provided but for other actions it could pose problems... Forewarned is forearmed! length2excel.lsp Quote
pmadhwal7 Posted March 5, 2024 Author Posted March 5, 2024 19 hours ago, Tsuky said: @pmadhwal7 Here's an improved version that should work better. But before using it, an overlap inconsistency between 2 polylines exists in your drawing that you must correct. To help you locate them, copy/paste these two lines successively and make the desired correction. (redraw (handent "2FD") 3) (redraw (handent "2FE") 3) On the other hand I noticed many duplicate vertices on many polylines especially at the start and/or at the end, this does not pose a problem for the program provided but for other actions it could pose problems... Forewarned is forearmed! length2excel.lsp 2.83 kB · 3 downloads thanks for help i was tried the given code but it was export only first line length Quote
Tsuky Posted March 5, 2024 Posted March 5, 2024 Depending on the reference point you choose on the base polyline ("Designate an end point of the base polyline:"), the result will be different. This determines the direction for the search. So try with the other opposite point. NB: Bad translation : Designate an end point of the base polyline: -> Designate an start point of the base polyline: Quote
