Aditya Bagaskara Posted February 16, 2024 Posted February 16, 2024 I've previously never used custom CTB in any way. I always use layers instead to assign lineweights and distinguishing my objects. I want to learn how to use CTB but first, Why should I use CTB? IS CTB has more advantage than Layers? If I only use CTB as a way of organizing lineweights, should I stop using layers (just use layers as a organizational tool)? Quote
BIGAL Posted February 17, 2024 Posted February 17, 2024 We always used CTB but that follows on from the old ISO drafting pen standards, 0.18 -> 1.0 So the 1st 8 colors matched the pen lineweight required, so layer color was used for pen weight. The remaining colors were set to 0.25 and by color so a true color would be printed. We also changed pen weights for say JPG etc and had multiple ZCTB's even one for all black. Quote
tombu Posted February 28, 2024 Posted February 28, 2024 The advantage of assigning lineweights & linetypes with layers is they are displayed in the Layer Manager and can be quickly set with Layer States. Controlling only 4 lineweights & 10 linetypes in a CTB would require 40 Plot Styles for each color you use. Using layer assigned lineweights & linetypes an STB with only 6 Plot Styles can allow plotting with all colors not just the 256 recognized by a CTB using all the lineweights & lineweights you have as well as black, 3 grayscales and a shade of the assigned color. Since each Plot Style in a STB has a distinct name & can be assigned to any object or layer name it needs research and implementation as a company standard. As different STBs use different Plot Style names switching from one STB to another is a lot more complicated so everyone using them need to work with the same STB. I found in AutoCAD there's at least a few ways to do everything intentionally, work with the one that best suits your organization. If your company plots everything in black & white you don't need the power of a STB. Quote
