Ham007 Posted February 27, 2009 Posted February 27, 2009 Does anyone have an Auto LISP routine to assign Page Setup to drawings? I have a lot of drawings and I have two different printers and I don't know what to do to assign the same page setup at once to all of them so I can use the Publish command to print the drawings. I will appreciate your help and/or comments. Thank you! Quote
JohnM Posted February 27, 2009 Posted February 27, 2009 If it’s just a matter of what printer to send to: just select the multi-sheet DWF option in the publish dialog. Publish the drawings and then click the view dwf button then go to file and plot and select a printer from the list and select the other print choices and your done. Quote
chelsea1307 Posted February 27, 2009 Posted February 27, 2009 you could also just create a page setup for each printer (only once) then while in publish move whatever dwg has the page setup to the top ctrl select which dwgs you want to have that page setup and scroll down to it and it will use the same one for all that are selected Quote
JohnM Posted February 28, 2009 Posted February 28, 2009 are you just wanting to change printers or page sizes? Quote
JohnM Posted March 4, 2009 Posted March 4, 2009 to just change printers look at my post above about using publish and your done Quote
VVA Posted March 5, 2009 Posted March 5, 2009 Try It. First Your must save named page setups in layout 1. Switch to layout 2. Type command _Plot 3. Save page setups or import saved page setups from other drawing using command _PSETUPIN Then type CPSSL (Change Page Setups on Selected Layouts) in command line, and select saved page setups and layuots. After name of page setups or layout name the format and sheet orientation is written (P -portreight L - landscape ) PS. Sorry for my poor English cpssl.lsp Quote
Ham007 Posted March 5, 2009 Author Posted March 5, 2009 VVA: Thank you so much for your response and you don't have a poor English!! Thank you again!! Thank you all for your responses and your help!! Quote
