I have closed the ribbon and set up a custom workspace without it, but it reopens every time I open anything, and I have to close it again.  I see it load up in the command line each time I open a drawing (_RIBBON).  Is there any way to stop AutoCAD from doing this?  I’m using 2022.
Edited by Croweyes1121
In the workspace did you save it after changing ? Also make sure you have auto update turned off.
I did save the workspace for sure.  It comes back under my saved name when I open another drawing.
Not sure about the auto update, though.  How do I check that?
